Autocad Plant 3D 2017 does not initialize (windows 10)
Message 1 of 25
Hi...
My Autocad Plant 3D 2017 does not initialize, the software is install in windows 10.
Replies (24)
Message 2 of 25
Mark.Lancaster
@Anonymous
I would do the following:
1.  That you have full admin rights to your PC.
2.  Your video card driver version is the latest.  Do not rely on Windows telling you it is..  Go directly the Vendor's web site.
3.  Clean out your personal temp (%temp%) folder.
Good luck and report back on your progress.
Mark Lancaster
Message 3 of 25
Hi @Mark.Lancaster.
I did everything that indicated .
1 - I am the total administrator of my computer
2 - My video card works normally
3 - I've already cleaned the entire "Temp" folder.
It did not help. Would you have another solution?
Message 4 of 25
Mark.Lancaster
For a test..  Right mouse click on the Plant 3D desktop icon and select run as admin..  What happens then?
Update: Also what sub-folders do you see under C:\Programdata\Autodesk\CLM\LGS?
Mark Lancaster
Message 5 of 25
Same thing... Does not start the software.
Message 6 of 25
Mark.Lancaster
Did you see my update on my reply?
Folder information under C:\Programdata\Autodesk\CLM\LGS
Mark Lancaster
Message 7 of 25
Hi...
One print my folder´s...
Message 8 of 25
Mark.Lancaster
@Anonymous
Ok..  For a test create that folder structure of C:\Programdata\Autodesk\CLM\LGS..  Launch the application, does it work now?
Mark Lancaster
Message 9 of 25
Hi @Mark.Lancaster.
I reinstalled the software and now own the folder. But the problem perciste.
Message 10 of 25
Mark.Lancaster
@Anonymous
IN that folder structure what do you see now?  Just because the folder structure is there doesn't mean it has all the required files.
Mark Lancaster
Message 11 of 25
Hi @Mark.Lancaster
Good morning.
It has the files inside it.
None of the aforementioned alternatives made the program work.
Message 12 of 25
Mark.Lancaster
What files are there...
Mark Lancaster
Message 13 of 25
Has only one file: (.lgs.data)
Message 14 of 25
Mark.Lancaster
What does it state inside of the LGS.DATA file?  Its a text file and can be opened with notepad
_USER
_STANDALONE
_NETWORK
Update:  ALso perform these steps
I stole this wording/reply from my buddy @Darin.Green, so he takes all the credit for the steps..  Smiley Wink
This should help get your application working. Assuming you have a valid serial number/contract.
Close the application
On your computer, navigate to: ​​C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F  [<Product Key> is the product key of the Autodesk Application you have]
Delete the LGS.data file.
Navigate to C:\Users\\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
Start the application.
When you start the application, it will prompt you to choose one of the following:
Login - 30 day trial licenses
Serial Number - Standalone and Single-User activation
Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.
Mark Lancaster
Message 15 of 25
Hi @Mark.Lancaster
I did everything that guided me. Until I restart the computer and still have the same problem.
Message 16 of 25
natasha.l
Hello @Anonymous,
Sorry for the inconvenience. Please try to conduct a clean uninstall of the AutoCAD Plant 3D 2016 & 2017 currently installed, please follow the steps below.
-Clean Uninstall of the program
-Update your System (Windows & Java)
-Temporarily disable your antivirus & firewall
-Go to Autodesk Virtual Agent find the program
-Download all of the parts (in this case Part 1 & 2 )
-Follow the steps in this link Installing products from the Virtual Agent
-Locate the download folder and extract (double click) part _001_00X.sfx.exe. If you have a permission issue right click and select, Run as administrator.
-Files will be directed to C:\Autodesk
-Follow the prompts to install the program
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!"
Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
Please let me know if you have any further questions and keep us posted.
Message 17 of 25
Hi @natasha.l
Again, to no avail ...
Message 18 of 25
natasha.l
Hello @Anonymous,
Please try using the following tool it is intended to provide assistance in identifying the root cause and provide a suggested solution.
AIDA Autodesk® Installation Diagnostic Assistant
Download Link:  http://www.autodesk.com/aida  > Run the tool > attach the log to your reply
Thank you.
Message 19 of 25
Hi @natasha.l
I downloaded and installed AIDA. It does the scanning and gives a message, when the "ok" the message disappears and does no other action. Attached is a "print" of the message.erro initialization plant 3d_02.png
Message 20 of 25
natasha.l
Hello @Anonymous,
In the C:\Autodesk\Autodesk_Maya_2017_EN_JP_ZH_Win_64bit_dlm\3rdParty folder for Maya these redistributable are stored here.
-Repair the items listed in your Control Panel > sort by "Installed On"
x64 & x86 Microsoft  Redistributable
2010 SP1
2012 UPD4
2013
2015
-If the repair does not work, then try to uninstall them.
-Then, reinstall them all back on the machine by visiting the Microsoft website.
Please keep us posted. Smiley Happy
