I am trying to start a trial of AutoCad LT to see if I want to purchase a license and am having errors starting up the application.
I can open the start window where it gives the option to select a license type or start a free trial, but as soon as I click any of them, the application stops responding and eventually quits.
I am running Mojave version 10.14.2 and my computer more than meets the rest of the system requirements. I have attached the output from the system log below.
Jan 9 16:11:57 iMac [BrowserExtension][12994]: [2019-Jan-09 16:11:57.470394] Cannot find AdWebServices configuration directory
Jan 9 16:13:42 iMac [Script][12994]: [2019-Jan-09 16:13:42.880803] jsO2ServicesController - load login state failed
Jan 9 16:13:42 iMac [Script][12994]: [2019-Jan-09 16:13:42.881444] jsO2ServicesController - load login state failed
Jan 9 16:13:42 iMac [Script][12994]: [2019-Jan-09 16:13:42.889111] DefLic.getLicenseInfo - failed to get license info because: undefined is not an object (evaluating 'this.globalJsonArgs.userId')
It seems to be failing because I do not have a defined userID, but I imagine this should not be an issue since I am just trying to start a free trial.
Any insights into why this might be happening would be very helpful.
Thanks in advance!
Solved by colette.z.herrick. Go to Solution.
Have you tried reinstalling it?
Also, in your account manager do you show a Serial number or does it say: Sign In
Mike
Hi Mike,
Thanks for getting back to me.
I have uninstalled and reinstalled it twice and also restarted my computer. In the License Transfer Utility (not sure if the account manager is something separate) it shows a serial number of all 0s.
Completely uninstall and check https://manage.autodesk.com to see if trial is shown in your account.
I uninstalled it and nothing is shown under the Trials section of the account manager.
Are you installing as admin with any firewalls disabled?
I am installing it as an admin but have not changed anything with the firewall.
When did you activate the trial?
So what do you see in your Account manager for AutoCAD LT MAC itself?
Do you see a serial number or a just sign in?
What do you see when you're trying to activate it?
@colette.z.herrick It's been a couple days since you last posted,
Is everything working or do you still need help,
as @mdavis22569 check: manage.autodesk.com
The trial has never actually been activated. The application stops responding and quits when I press the "start a free trial" button so I haven't gotten through actually starting a trial.
I finally got the application working. In the startup screen, if I clicked "single user", "start a trial," or whatever the "joint user" choice was, the application would immediately stop responding and crash. However, you have to click "enter a serial number" and the free trial will activate without you having to enter a serial number.
Seems like kind of a strange design choice but I am just glad I got the trial working.
Thanks for all your help!
Glad it's fixed,
Happy to help,
Have a good day.
Hello @colette.z.herrick,
Glad you resolved your issue, I just wanted to check on why the License Utility was used to start a trial?
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
