Installation & Licensing
AutoCad LT 2019 on Mac Not Responding on Startup
13 REPLIES 13
Message 1 of 14
colette.z.herrick
1502 Views, 13 Replies
I am trying to start a trial of AutoCad LT to see if I want to purchase a license and am having errors starting up the application.
I can open the start window where it gives the option to select a license type or start a free trial, but as soon as I click any of them, the application stops responding and eventually quits.
I am running Mojave version 10.14.2 and my computer more than meets the rest of the system requirements. I have attached the output from the system log below.
Jan 9 16:11:57 iMac [BrowserExtension][12994]: [2019-Jan-09 16:11:57.470394] Cannot find AdWebServices configuration directory
Jan 9 16:13:42 iMac [Script][12994]: [2019-Jan-09 16:13:42.880803] jsO2ServicesController - load login state failed
Jan 9 16:13:42 iMac [Script][12994]: [2019-Jan-09 16:13:42.881444] jsO2ServicesController - load login state failed
Jan 9 16:13:42 iMac [Script][12994]: [2019-Jan-09 16:13:42.889111] DefLic.getLicenseInfo - failed to get license info because: undefined is not an object (evaluating 'this.globalJsonArgs.userId')
It seems to be failing because I do not have a defined userID, but I imagine this should not be an issue since I am just trying to start a free trial.
Any insights into why this might be happening would be very helpful.
Thanks in advance!
13 REPLIES 13
Message 2 of 14
Have you tried reinstalling it?
Also, in your account manager do you show a Serial number or does it say:   Sign In
Mike
Mike Davis
Message 3 of 14
Hi Mike,
Thanks for getting back to me.
I have uninstalled and reinstalled it twice and also restarted my computer. In the License Transfer Utility (not sure if the account manager is something separate) it shows a serial number of all 0s.
Message 4 of 14
Completely uninstall and check https://manage.autodesk.com to see if trial is shown in your account.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 5 of 14
I uninstalled it and nothing is shown under the Trials section of the account manager.
Message 6 of 14
Are you installing as admin with any firewalls disabled?
Leo Warren
Message 7 of 14
I am installing it as an admin but have not changed anything with the firewall.
Message 8 of 14
When did you activate the trial?
Leo Warren
Message 9 of 14
Hi @colette.z.herrick
So what do you see in your Account manager for AutoCAD LT MAC itself?
Do you see a serial number or a just sign in?
What do you see when you're trying to activate it?
Mike Davis
Message 10 of 14
@colette.z.herrick It's been a couple days since you last posted,
Is everything working or do you still need help,
as @mdavis22569 check: manage.autodesk.com
Leo Warren
Message 11 of 14
The trial has never actually been activated. The application stops responding and quits when I press the "start a free trial" button so I haven't gotten through actually starting a trial.
Message 12 of 14
I finally got the application working. In the startup screen, if I clicked "single user", "start a trial," or whatever the "joint user" choice was, the application would immediately stop responding and crash. However, you have to click "enter a serial number" and the free trial will activate without you having to enter a serial number.
Seems like kind of a strange design choice but I am just glad I got the trial working.
Thanks for all your help!
Message 13 of 14
Glad it's fixed,
Happy to help,
Have a good day.
Leo Warren
Message 14 of 14
Hello @colette.z.herrick
Glad you resolved your issue, I just wanted to check on why the License Utility was used to start a trial?
Administrator Productivity
