Installation & Licensing
Autocad LT 2006 installation on WIN 7 64 Bit Fujitsu PC
1 REPLY 1
1202 Views, 1 Reply
I try to install Autocad 2006 LT on a PC : WIN 7 Pro, SP1, 64 Bit on a Fujitsu, 8 GB Ram Here´s the following error : [2/15/2016 13:49:46] === Installation started on XXXXXXXX === [2/15/2016 13:49:50] [Info] Windows Installer upgrade is not required [2/15/2016 13:49:50] System Version = 5.0.7601.18637 [2/15/2016 13:49:50] Installation skipped: MSI Runtime 3.0 [2/15/2016 13:49:50] [Info] .NET Framework Runtime upgrade is not required [2/15/2016 13:49:50] System Version = 4.0.40305.0 [2/15/2016 13:49:50] Installation skipped: .NET Framework Runtime 1.1 [2/15/2016 13:49:50] [Info] .NET Framework Runtime upgrade is not required [2/15/2016 13:49:50] System Version = 4.0.40305.0 [2/15/2016 13:49:50] Installation skipped: .NET Framework Runtime 1.1 SP1 [2/15/2016 13:49:50] Installation skipped: .NET Framework Runtime 1.1 Language Pack can't be installed on Windows 64-bit [2/15/2016 13:49:50] Installation aborted [2/15/2016 13:49:51] === Installation ended === It seems it usually doesn´t work. I tried to install in XP-Virtual Machine but the performace is horrible and there is no Homenetwork access (Printers/Nas). I tried to install on WIN 7 diagnostic start with only the windows installer active. It worked, but after reswitch to normal mode I had to run Autocad as an Admin and under compatiblity mode WIN 98/ME and still no Homenetwork. Is it possible to run Autocad LT 2006 on WIN 7 64 Bit ?? And how does it work ??
1 REPLY 1
Mark.Lancaster
Rainer.Seebauer
Welcome to the community..
I'm not even sure LT2006 will even install and work on WIn 7 64B machine.  Its old and an obsoleted product.   Is there a reason why you need LT 2006?  Can you use a newer version?
Mark Lancaster
Administrator Productivity
