Installation & Licensing
AutoCAD Installation Error; "Aborted.(Error: 9)"
99 REPLIES 99
Message 1 of 100
71874 Views, 99 Replies
I'm having trouble installing AutoCAD 2014 ...
After proceeding with the download, the loading task bar fails when it reaches 98% with the report, "Aborted. (Error 9)."
This is the first time I've had trouble downloading anything from Autodesk. If anyone has advice, I would greatly appreciate any correspondence. Thanks!
99 REPLIES 99
Message 21 of 100
in reply to: ukdxb012
it is now starting to download i hope it will be installed soon .. kudos this ! thanks
Message 22 of 100
I can't do that because your advice did not help at all. Doesn't anyone know how to fix this? really need the software pls.
@DuncanBrannan82 wrote:
Is this the error of which you speak... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-R...
Did you download the product via the Autodesk Virtual Agent... http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk... if not it might be worth redownloading the file.
Message 23 of 100
ukdxb012
I believe the issue maybe connected to your broadband. Do you have a cap on your download? It might be worth you trying to use Download Manager to download the product in stages so you dont use all of your broadband cap. Download Manager has the ability to pause the download so you can continue another day.
Try using Download Now and remember to do it in stages... i'd be interested to hear if this fixes things for you.
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 24 of 100
ukdxb012
Message 25 of 100
in reply to: matthew.d
Error 9 = there is a folder or filename "Autodesk" in your disk C.
Before installing autocad make sure to remove all folders or files with name "Autodesk" in C.
No problem after doing this lol
Sincerely yours.
Message 26 of 100
Will the procedure using virtual agent work for the educational version?
Message 27 of 100
camilo.lemos
Hi @Anonymous and welcome to the Autodesk Community!
The Virtual Agent procedure will work with educational versions. The only extra step will be activating the product using the serial number and product key provided by the Education Community upon your first download attempt in the Community.
I hope this helps!
Camilo Lemos
Message 28 of 100
in reply to: camilo.lemos
Thanks man it works!
Spoiler
Message 29 of 100
we have a problem with the instalation of  Autocad 2016,trial version because, we download the pack file, and when we execute this one, automatically says error 9 aborted, please tell us the steps to correct the mistakes.
Message 30 of 100
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried all of the previously posted suggestions?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 31 of 100
hi! thanks for your quickly answer, yes, in fact, we did some of things written here, but, the problem continues
Message 32 of 100
search these terms "Autocad" or "Autodesk" in your disk C and remove all corresponding's files.
tell me for the result.
Have fun
Message 33 of 100
just wanted to inform you that it can't be an issue with Key Or Registration, because I don't even have the program installed yet. I am trying to install the TRIAL VERSION that should not require any activation so this information regarding Error 9 is incorrect.
Message 34 of 100
i get the same trouble, i tried to download autocad 2016 education.. help Smiley Sad
Message 35 of 100
Hi you,
To solve "error 9" you should make 2 step:
1. Uninstall all previous auto cad.
2. Make sure empty folder %tempt % (in Run window).
Now you can install new auto cad software.
Regard.
Message 36 of 100
Message 37 of 100
Try running the setup as an administrator. worked for me
Message 38 of 100
Thanks a lot
Message 39 of 100
hi i seem to face similar problem. here is what i did so i can install the student free trial
i deleted all files that contain autoca from previous installation. i turn off the firewall and uac.
i unabled to downlooad it even all steps are done. can u help me with it?
Message 40 of 100
matthew.d
Hi @Anonymous,
Sorry to hear about the issue. Make sure to keep your contact information up to date using Register Once, where you can add an account with your current information, register products to that account, and delete your old accounts, or those with outdated information.
If you are still experiencing the issue:
Educational users: please submit a request for assistance with the education community.
Subscription users: please submit a case with activation and registration.
Matt DiMichele
Administrator Productivity
