Installation & Licensing
Autocad 2021 Installer for Mac not responding
21 REPLIES 21
Message 1 of 22
2616 Views, 21 Replies
I downloaded Autcad2021 for Mac earlier but it tends that the application is not responding. How do I fix this?
My macOs is Catalina 15.5
Tags (1)
21 REPLIES 21
Message 2 of 22
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous
Can you provide more details about the problem? What steps did you follow to install? When the installer stopped to respond?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 22
in reply to: maxim_k
None. I just opened the installer but nothing happens.
Message 4 of 22
maxim_k
Do you have stable Internet connection? What about Firewall on your side?
Have you tried to restart your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 22
Yes I have. I also restarted my mac many times.
Message 6 of 22
maxim_k
I think it is better to ask your question on dedicated Forum :
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
You should get better and faster support there.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 22
maxim_k
Is your problem similar to this one:
https://forums.autodesk.com/t5/installation-licensing/auto-cad-2021-installer-does-not-launch/td-p/9...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 22
None. As I try to open the installer, it does nothing.
Message 9 of 22
maxim_k
What settings do you have in Security & Privacy pane of macOS System Preferences?
Here:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 22
Yes but my OS is Catalina 10.15.5
Message 11 of 22
maxim_k
Just noticed on screenshot you posted that the icon of AutoCAD installer looks strange. It should look like this one:
Where did you get installation image (dmg) for AutoCAD 2021?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 22
I got it from the autodesk site.
Message 13 of 22
It's the same.
Message 14 of 22
Message 15 of 22
danielelanote
I'm having the same issue. How can i fix it?
Message 16 of 22
maxim_k
in reply to: danielelanote
Hi @danielelanote ,
Can you provide more details about your problem?
What macOS do you have on your Mac?
What AutoCAD for Mac version are you trying to install?
What happens when you run the installer?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 22
danielelanote
Sure,
I'm using Monterrey 12.2.1.
I could install Autocad removing all files and folders from /Library/Application Support/Autodesk.
Then I was able to install Autocad, but when I click "Enter a serial number", nothing comes up and Autocad seems to crash and quit. I have tried the same with different versions (2020, 2021, 2022) and the same thing happens in all of them.
(Translate: application not responding)
Message 18 of 22
maxim_k
Hi @danielelanote ,
I think you should try the solution from here:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/License-c...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 22
danielelanote
That's work perfect. Thanks!
Message 20 of 22
joe.abelDWPTZ
I have the same issue but I am not able able to install the AutoCAD.
I am using a 2020 mac, intel core with Monterey 12.2.1
Administrator Productivity
