Hello everyone,
Yesterday I installed AutoCAD 2019 under my student license, double-clicked on the icon, the welcome screen appeared and just when you would expect the UI to load, the welcome screen disappeared and that's it. Nothing more.
Things I tried without success.
I just installed Revit 2019 and it worked like a charm.
If it helps to troubleshoot, I still have the 2018 versions of the two softwares installed as well.
Thank you in advance.
Daniel
Hello @Anonymous,
Sorry to hear this is happening.
You can try another method called a Browser Download, if the other methods have not worked for you.
I have listed some steps to prepare your system for download and installation in case you run into a problem.
If the above does not resolve it, try to re-create the event/pull up the error again & locate the event error looking at the date & time, using Event Viewer. Let us know what you find.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
Natasha
Helpful Links:
I have another problem, I uninstalled the program and when I try to install it again , it wants to download the content again although they are on my disk
Me too... except it is only when my computer is not connected to my home office network. It does not start when I am tethering with my phone or on my clients networks. That has got to be simple...
Your reply is a little confusion and I can't figure out when AutoCAD 2019 works and doesn't work for you. Can you clarify?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Autocad 2019 will start only on my office network…when I use my phone for internet connection using tethering or my client’s network (using an ethernet cable) to connect to the internet it will NOT start. It simply goes through a couple of screens and slows down the entire computer as if something gets the CPU very busy…
