Installation & Licensing
AutoCAD 2019 for Mac Trial version quits
6 REPLIES 6
399 Views, 6 Replies
Hi, I have MacOs High Sierra [10.13.6]. The AutoCAD 2019 trial version quits whenever I try to open a dwg or a dwt file (even if it is a template file include in the software or a dwg sample file downloaded from the Autodesk site.)
Any suggestion?
Thank you
Any suggestion?
Thank you
6 REPLIES 6
maxim_k
maxim_k
Welcome to Autodesk Forums!
Hi Balazs,
Does it quits or crashes?
Do you see crash report?
How do you open drawings? From Finder by double-clicking on DWG or from within AutoCAD itself?
Are you able to launch AutoCAD at least and see new drawing? Or everything end-ups with Welcome screen?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Balazs,
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Hi Maxim,
It quits when I choose a file to open. No crash report.
I have tried every option to open a file: from within AutoCad (from welcome screen and from the file menu), double click and right click the file and choose the aplication.
I was not able to see/open any file in AutoCad. Quits righ after choosing a file to open.
Hi Maxim,
maxim_k
maxim_k
Can you try to create new user account on your Mac in Users&Groups pane of macOS System preferences (do not use Guest account)? This is just for test - later you can delete it.
Login to the new account and test AutoCAD - does it crashes now?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
It works with a new User. Thanks for your help!
What can be the reason that it is not working with my original/default User name?
maxim_k
maxim_k
I think you have permissions problem in your initial user account which is very hard to diagnose.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
OK, thanks!
All the best,
Balázs
OK, thanks!
All the best,
Balázs
Administrator Productivity
