Product: | Autodesk AutoCAD 2018 | |
Serial Number: |
Product Key: | 001J1 | |
Request code: | 7T9E TLR7 PETT 6C1Q Q65U 6FZK 8SKW KYPZ |
I need an activation code or other solution to continue working on AutoCAD.
Preferably, I want the same version (2018).
If I need a newer version it must be the one most similar to 2018
Important - I do not want a version that creates the small print "created by an Autodesk student version" when you PDF the document.
Louis
louisjag@gmail.com
Solved by leowarren34. Go to Solution.
I wouldn't post to much personal information here
However I would go back and look in your Account manager .. you should now have a SIGN IN activation vs using the serial number
Hi @louisjag,
2018 Products are no longer within support for the Education Program. Currently, AutoCAD 2019 is the oldest version available however this will be out of support for education users next year.
As for the watermark, there is no choice here as you have to have it where it's in the software, since your work is non-commercial by nature, to be in line with the Education Program EULA, so it shouldn't matter. At the end of the day you are getting free access to software, so you can expect some limits with its usage.
Do you have a VALID subscription for AutoCAD 2028?
That's needed.
Also, you can't use it for educational if that's what you're wanting it for.
@rohith.rocker999 wrote:
i need the activation code for autocad 2018
Help yourself here https://ava.autodesk.com/modular/?module=edu&from=il_forum&_ga=2.242924354.133992433.1669037926-4949...
Firstly, which version are you using, and is it educational or commercial license.
Secondly, Autodesk is retiring plans based on serial numbers and assigning each subscription to a named user. Meaning, you no longer need a Serial Number's to be able to use software. You just have to sign in to the software with your account, and it's done.
If you have a valid educational license you can use 2023 through 2021 ..
