I am getting the below issues while trying to install AutoCAD 2018 into my machine from the links. Would you be ablet to help?
http://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/98E220D3-8EEE-49BC-8A77-0FC24FEE271C/SFX/AutoCA...
Solved by CGBenner. Go to Solution.
Solved by mdavis22569. Go to Solution.
Solved by elisabetta_meggiolaro. Go to Solution.
what OS are you currently on?
Also, is the error when it's running or during the installation?
and this update
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Civil-3D-2018-cras...
Hi Mike,
I am on Windows 11 Pro x64. The error runs when I open AutoCAD and it closes down immediately - the installation was fine.
Elisabetta
Morning @elisabetta_meggiolaro
Unfortunately, that's the issue. W11 isn't supported for 2020 and older versions, and C++/NET is an issue.
Soory I don't have better news.
The reason I installed AutoCAD 2018 is because I wanted to use Vehicle Tracking 2018 license with it. Is there any other way I can use Vehicle Tracking itself with an old Autodesk license and not the AEC collection? Thank you.
Regards
Gotcha..
Do you have access to a W10 machine?
Yes, I do have also access to W10 machines. Would version 2018 work in those? Thank you for your help.
Yes with all of the updates:
Operating System |
@elisabetta_meggiolaro Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
