AutoCAD 2018 installation issue
elisabetta_meggiolaro
Replies (8)
mdavis22569
what OS are you currently on?
Also, is the error when it's running or during the installation?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhand...
and this update
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Civil-3D-2018-cras...
Mike Davis
Hi Mike,
I am on Windows 11 Pro x64. The error runs when I open AutoCAD and it closes down immediately - the installation was fine.
Elisabetta
mdavis22569
Morning @elisabetta_meggiolaro
Unfortunately, that's the issue. W11 isn't supported for 2020 and older versions, and C++/NET is an issue.
Soory I don't have better news.
Mike Davis
The reason I installed AutoCAD 2018 is because I wanted to use Vehicle Tracking 2018 license with it. Is there any other way I can use Vehicle Tracking itself with an old Autodesk license and not the AEC collection? Thank you.
Regards
mdavis22569
Gotcha..
Do you have access to a W10 machine?
Mike Davis
Yes, I do have also access to W10 machines. Would version 2018 work in those? Thank you for your help.
mdavis22569
Yes with all of the updates:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
Operating System
  • Microsoft® Windows® 7 SP1 (32-bit & 64-bit)
  • Microsoft Windows 8.1 with Update KB2919355 (32-bit & 64-bit)
  • Microsoft Windows 10 (64-bit only) (version 1607 and up recommended)
See Autodesk's Product Support Lifecycle for support information.
Mike Davis
CGBenner
@elisabetta_meggiolaro Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
