Hey guys,
I have a huge problem regarding my AutoCAD 2016 installation after I had upgraded to Windows 10.
First, the AutoCAD program that I had installed was not installed properly and I got redirected to an error page where it said that a software problem had caused AutoCAD 2016 to stop working. Nevertheless it was marked as completed so I tried to open it. The splash screen loads, but after that, the program crashes. That meant thatcould not access the activation page and actually start opening my projects.
Other Autodesk programs are working fine. It's just this program that is not working. I had uninstalled of the Autodesk Content in the computer and even went to the registry to delete all the Autodesk Files.
Computer Specs: Acer Aspire ES1-512-P0SY
OS Version: Windows 10
Graphics: Intel (R)HD Graphics
Carl
Even with the DirectX 9 setting was applied (1st reply to the solution), the application still crashed. I think this is a new problem that I haven't seen in the other Autodesk Applications before. I still haven't received any solutions from the Autodesk CER in the mail so I'm suspecting that this might be one.
Anyone with a solution? I'm still facing all the problems in the computer even after installing and reinstalling.
Error in the licensing.
2684 2015/10/03 22:06:50 Reason=License import
2684 2015/10/03 22:06:50 ComputerName=大多喜城
2684 2015/10/03 22:06:50 OS=6.2.9200.
2684 2015/10/03 22:06:50 XmlCode=PRODUCT=ACD;VERSION=2016_0;RELEASE_TYPE=F;DEPLOY_TYPE=S;FUL_TYPE=FL
2684 2015/10/03 22:06:50 LicenseStatus=1.1.0
2684 2015/10/03 22:06:58 Reason=Fatal error
2684 2015/10/03 22:06:58 ComputerName=大多喜城
2684 2015/10/03 22:06:58 OS=6.2.9200.
2684 2015/10/03 22:06:58 File=AdlmFlxActAppLicenseStateHandler.cpp,Line=378
2684 2015/10/03 22:06:58 AdlmActError=306 [Fatal error from Register Today call]
2684 2015/10/03 22:06:58 File=ltuManager.cpp,Line=170
2684 2015/10/03 22:06:58 VendorID=2 [ADLMACT]
2684 2015/10/03 22:06:58 VendorError=306 [Fatal error from Register Today call]
2684 2015/10/03 22:06:58 File=ltuManager.cpp,Line=171
2684 2015/10/03 22:06:58 LTUError=1 [LTU import or export failed]
13284 2015/10/03 22:07:10 Reason=License import
13284 2015/10/03 22:07:10 ComputerName=大多喜城
13284 2015/10/03 22:07:10 OS=6.2.9200.
13284 2015/10/03 22:07:10 XmlCode=PRODUCT=ACD;VERSION=2016_0;RELEASE_TYPE=F;DEPLOY_TYPE=S;FUL_TYPE=FL
13284 2015/10/03 22:07:10 LicenseStatus=1.1.0
13284 2015/10/03 22:07:26 Reason=License import
13284 2015/10/03 22:07:26 ComputerName=大多喜城
13284 2015/10/03 22:07:26 OS=6.2.9200.
13284 2015/10/03 22:07:26 XmlCode=PRODUCT=ACD;VERSION=2016_0;RELEASE_TYPE=F;DEPLOY_TYPE=S;FUL_TYPE=FL
13284 2015/10/03 22:07:26 LicenseStatus=1.1.0
13284 2015/10/03 22:07:47 Reason=Fatal error
13284 2015/10/03 22:07:47 ComputerName=大多喜城
13284 2015/10/03 22:07:47 OS=6.2.9200.
13284 2015/10/03 22:07:47 File=ltuManager.cpp,Line=170
13284 2015/10/03 22:07:47 VendorID=2 [ADLMACT]
13284 2015/10/03 22:07:47 VendorError=2 [An operation is cancelled]
13284 2015/10/03 22:07:47 File=ltuManager.cpp,Line=171
13284 2015/10/03 22:07:47 LTUError=1 [LTU import or export failed]
