Installation & Licensing
AutoCAD 2016 Network License Error
11 REPLIES 11
Message 1 of 12
664 Views, 11 Replies
When we open Autocad 2016 it shows License error . Its not working with which registered serial number clasing with another network license number and it stop working. This Serial Number:xxx-xxxxxxxx is clasing with xxx-xxxxxxxx.
@Anonymous the post has been edited by @michele.mk to protect sensitive data (serial number)
11 REPLIES 11
Message 2 of 12
ennujozlagam
ennujozlagam
hello, you can try to refer to this LINK previous thread maybe can help. thanks
Message 3 of 12
Mark.Lancaster
Mark.Lancaster
@Anonymous
The -4 error indicates there's no more license left.  Can you confirm that?
Mark Lancaster
@Anonymous
Mark Lancaster
Message 4 of 12
natasha.l
natasha.l
Hello @Anonymous,
Welcome back.
Please locate Lmtools  in C:\Autodesk \Network License Manager (folder) then Config Services Tab > View Log Button. Also include Server Status Tab > Perform Status Enquiry  & please attach the results.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Hello @Anonymous,
Welcome back.
Message 5 of 12
natasha.l
natasha.l
Hello @Anonymous,
I wanted to check-in with you, can you please provide the information to further assist you?
Thank you.
Hello @Anonymous,
Thank you.
Message 6 of 12
in reply to: Mark.Lancaster
Hi, License is available. i also checked the serial number through REGEDIT and it shows different serial number which i gave at the time of installation, but when we are going to launch auto cad then it shows no license available. we have 2 license for Auto CAD 2016 .
Message 7 of 12
in reply to: natasha.l
Still facing same network license issue.  We request you to guide us in order to change serial number AutoCAD 2016 application. It was classing with another network license.
Message 8 of 12
Mark.Lancaster
Mark.Lancaster
@Anonymous
There's no need to change the serial # in the application.  It uses the serial # it gets from the license manager.
Are you saying you have 2 Autodesk license managers running?
Mark Lancaster
@Anonymous
Mark Lancaster
Message 9 of 12
We are running 2 Auto CAD 2016 with different serial numbers. means 2 license of 2016.
Message 10 of 12
Mark.Lancaster
Mark.Lancaster
@Anonymous
Ok..  But they (the 2 different serial numbers) should be in the same license file..  There's no need to have 2 license files to do this.
Update:  Meaning you combine both license into one by copying and pasting..
Mark Lancaster
@Anonymous
Mark Lancaster
Message 11 of 12
@Mark.Lancaster yes license file is only one.
Message 12 of 12
Mark.Lancaster
Mark.Lancaster
@Anonymous
I guess I'm confused at this point since you keep saying its clashing with another license.  Can you explain what you mean by this?
Mark Lancaster
@Anonymous
Mark Lancaster
Administrator Productivity
