When we open Autocad 2016 it shows License error . Its not working with which registered serial number clasing with another network license number and it stop working. This Serial Number:xxx-xxxxxxxx is clasing with xxx-xxxxxxxx.
@Anonymous the post has been edited by @michele.mk to protect sensitive data (serial number)
Solved by natasha.l. Go to Solution.
hello, you can try to refer to this LINK previous thread maybe can help. thanks
@Anonymous
The -4 error indicates there's no more license left. Can you confirm that?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @Anonymous,
Welcome back.
Please locate Lmtools in C:\Autodesk \Network License Manager (folder) then Config Services Tab > View Log Button. Also include Server Status Tab > Perform Status Enquiry & please attach the results.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
I wanted to check-in with you, can you please provide the information to further assist you?
Thank you.
Natasha
Helpful Links:
Hi, License is available. i also checked the serial number through REGEDIT and it shows different serial number which i gave at the time of installation, but when we are going to launch auto cad then it shows no license available. we have 2 license for Auto CAD 2016 .
Still facing same network license issue. We request you to guide us in order to change serial number AutoCAD 2016 application. It was classing with another network license.
@Anonymous
There's no need to change the serial # in the application. It uses the serial # it gets from the license manager.
Are you saying you have 2 Autodesk license managers running?
Mark Lancaster
We are running 2 Auto CAD 2016 with different serial numbers. means 2 license of 2016.
@Anonymous
Ok.. But they (the 2 different serial numbers) should be in the same license file.. There's no need to have 2 license files to do this.
Update: Meaning you combine both license into one by copying and pasting..
Mark Lancaster
@Anonymous
I guess I'm confused at this point since you keep saying its clashing with another license. Can you explain what you mean by this?
Mark Lancaster
