resulta que para descargar el programa me pide registrarme o crear una cuenta, ps resulta que ya estoy reguistrado pero cuando ingreso mis datos y le doy en " aceptar" no pasa de savieng... asi se puede quedar hasta horas, se queda cargando y bueno eso me aburre y lo cierro lo intento mas tarde y sigue con ese pendejo error..
alguna solucion?
Hi @Anonymous
Welcome to the Community.
Are you having issues with downloading and installing the software? If you only need the trial version of the software, you can try downloading the software installer from the Virtual Agent, as described here: Downloading Software using the Virtual Agent.
On the other hand, if your issue is with signing in to or creating an Autodesk Account, kindly refer to the information here on Creating an Autodesk Account.
Otherwise, if this is not the issue you are facing, kindly let us know by replying to this post and we will further assist you. Also, it would be greatly appreciated if you could possibly reply in English so we would be able to assist you better as well.
