Installation & Licensing
Adappmgr.exe not installing updates.
3 REPLIES 3
thomas.helms221
1452 Views, 3 Replies
Okay, So after extensively searching the forums, I finally decided to post to see if I could find a solution to my particular issue.
Background information
OS: Windows 8.1 Pro (Fresh install, all applicable updates applied)
Product: Autodesk Building Design Suite 2016 (Standalone License)
Product causing issue: Autodesk Application Manager (version: 5.0.142.0)
Issue Description
Autodesk Application Manager successfully finds and downloads updates, launches UAC prompt, after selecting yes, it appears the update just ceases to run.
Application log states:
DEBUG 2015-08-03T07:59:25.905 TID(11172) InstProxyIPCMgr::sendRequest: { "_APPID" : "AdAppMgr", "_PROTOCOL" : "ADAPPMGRSVC_1", "_REQUEST" : "INSTALLNEXT", "_USERID" : "ThomasHelms-PC-Thomas" }
DEBUG 2015-08-03T07:59:25.906 TID(11172) InstProxyIPCMgr::onRequestServerReadyRead: { "ErrorCode" : 6, "ErrorString" : "AdAppMgr:ThomasHxxxxxs-PC-Thomas is not registered.", "Status" : "ERROR" }
DEBUG 2015-08-03T07:59:25.906 TID(11172) InstProxyIPCMgr::sendRequest(response): { }
TRACE 2015-08-03T07:59:25.906 TID(11172) AdAppMgrSvcInstProxy: exited (0)
TRACE 2015-08-03T07:59:25.907 TID(11172) InstProxyIPCMgr::onRequestServerDisconnected
Any help resolving this issue would be greatly appreciated.
3 REPLIES 3
asburyj
in reply to: thomas.helms221
I am actually seeing this same type of error on another user right now. I haven't found a solution yet but I will post back here when I do. Just out of curiosity, what is the windows account username/computer name you are using?
Jeffry Asbury
thomas.helms221
in reply to: asburyj
It appears the old issue of a space in the user account name is back.  I tried the sulotion for that even though it was for an older version and it worked.  the account user name I was using was "Thomas Helms" the new account I created was "Admin"  So that appears to be the issue.
asburyj
Hi Thomas,
Yes we recently discovered the same thing. The Development team has been alerted and will work on a permanent fix. I am sorry to say that in the mean time you will need to use the workaround. Here's a link to that incase anyone stumbles upon this with the same issue.
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/When-the-Application-Mana...
Jeffry Asbury
Administrator Productivity
