Hi-
I need educational software, namely AutoCAD and Revit, for the summer semester at school. All the computers at school use the 2015 versions of autodesk products, but the only educational version available from Autodesk right now seems to be 2016. This wouldn't be a big deal in AutoCad, but for Revit, if I work on a model at home, I wouldn't be able to save down to work on it at school. Is there any way to get older versions of Educational licensed software?
Thanks in advance
Solved by camilo.lemos. Go to Solution.
Hi @Anonymous and welcome to the Autodesk Community!
Versions 2014, 2015 and 2016 of both AutoCAD and Revit are available for students from the Autodesk Education Community.
Can you please log in the Education Community and let me know if you still cannot see the versions all the versions I mentioned?
Thank you, and please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Ah, so it is. I only saw 2016 under the Suites available, which is why I was confused. Thanks!
is there any chance of getting a 2012 or Vista compatible version of AutoCAD thru educational student software? -Greg
short answer no
whatever versions are on the student community website is all you get for free
DarrenP
