Installation & Licensing
Activation Problem.
2 REPLIES 2
1011 Views, 2 Replies
Activation Problem.
Hallo,
I have problem with activation.
I installed version of AutoCAD 2017. Product Autodesk AutoCAD 2017, serial number xxx-xxxxxxxx, Kex of product 001l1. Activation error (0015.111)
2 REPLIES 2
Otto
Hello xgregoro and welcome to the Autodesk community!
It looks like you're seeing the following error when you try to start a product "Error (0015.111)". This issue typically occurs due to a corrupted licensing information file in local client. The following article(s) should help you resolve the problem:
How to force re-activation of a product
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Hallo,
I installed version of AutoCAD 2016. Product Autodesk AutoCAD 2016, serial number xxx-xxxxxxxx, Kex of product 001H1. Activation error (0015.111)
Administrator Productivity
