Installation & Licensing
activation error
4 REPLIES 4
467 Views, 4 Replies
activation error
I installed autocad 2014, but when i activate it, it says the serial number is invalid.  I had no problem with the serial number and product key when I installed it.  What is the problem?
Thank you
4 REPLIES 4
pendean
Activation is a license verification process: the error message usually means:
1. You entered in incorrectly. Type it all in again (no copy/paste).
OR
2. Someone used your 2014 license to upgrade to a newer version of AutoCAD.
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Are you using this as part of your new subscription? If you are, you will want to generate the entitlement by requesting the previous version, then the serial number will become valid.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
in reply to: pendean
thank you for your kind answer!
in reply to: matthew.d
I appreciate for your kind answer!!
Administrator Productivity
