I installed autocad 2014, but when i activate it, it says the serial number is invalid. I had no problem with the serial number and product key when I installed it. What is the problem?
Thank you
Solved by matthew.d. Go to Solution.
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Are you using this as part of your new subscription? If you are, you will want to generate the entitlement by requesting the previous version, then the serial number will become valid.
