When i try to install the programe i get this error. I have no idea what this means.
2016/5/5:17:03:37 kevindadmun KEVIN === Setup started on KEVIN by kevindadmun ===
2016/5/5:17:03:37 kevindadmun KEVIN Path_Length: 153
2016/5/5:17:03:37 kevindadmun KEVIN Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2016/5/5:17:03:37 kevindadmun KEVIN Launch
2016/5/5:17:03:37 kevindadmun KEVIN CommandLine /PK 128H1 /SN 900-49704181 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-...
2016/5/5:17:03:37 kevindadmun KEVIN Current Directory C:\Users\KEVIND~1\AppData\Local\Temp\_AID152.tmp
2016/5/5:17:03:39 kevindadmun KEVIN === Setup ended ===
2016/5/5:17:03:38 kevindadmun KEVIN === Setup started on KEVIN by kevindadmun ===
2016/5/5:17:03:38 kevindadmun KEVIN Path_Length: 153
2016/5/5:17:03:38 kevindadmun KEVIN Current Directory C:\Users\KEVIND~1\AppData\Local\Temp\_AID152.tmp
2016/5/5:17:03:38 kevindadmun KEVIN Launch
2016/5/5:17:03:38 kevindadmun KEVIN Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/5/5:17:03:38 kevindadmun KEVIN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/5/5:17:03:39 kevindadmun KEVIN PageOpen LaunchDialog
2016/5/5:17:03:53 kevindadmun KEVIN PageOpen LicenseDialog
2016/5/5:17:03:53 kevindadmun KEVIN PageOpen ProductInfoDialog
2016/5/5:17:03:53 kevindadmun KEVIN PageOpen ProductSelectionDialog2
2016/5/5:17:03:58 kevindadmun KEVIN PageOpen FullProgressDialog
2016/5/5:17:03:59 kevindadmun KEVIN Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/5/5:17:03:59 kevindadmun KEVIN Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/5/5:17:03:59 kevindadmun KEVIN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/5/5:17:03:59 kevindadmun KEVIN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/5/5:17:05:48 kevindadmun KEVIN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/5/5:17:05:48 kevindadmun KEVIN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/5/5:17:05:48 kevindadmun KEVIN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/5/5:17:06:24 kevindadmun KEVIN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/5/5:17:06:24 kevindadmun KEVIN Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/5/5:17:06:24 kevindadmun KEVIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/5/5:17:06:33 kevindadmun KEVIN Install DirectX® Runtime Succeeded
2016/5/5:17:06:33 kevindadmun KEVIN Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM.tar...
2016/5/5:17:06:33 kevindadmun KEVIN Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/5/5:17:07:18 kevindadmun KEVIN Install Autodesk® Material Library 2016 Succeeded
2016/5/5:17:07:19 kevindadmun KEVIN Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILB....
2016/5/5:17:07:19 kevindadmun KEVIN Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/5/5:17:07:42 kevindadmun KEVIN Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2016/5/5:17:07:43 kevindadmun KEVIN Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/5/5:17:08:59 kevindadmun KEVIN Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/5/5:17:08:59 kevindadmun KEVIN Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/5/5:17:09:21 kevindadmun KEVIN Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2016/5/5:17:09:57 kevindadmun KEVIN Rollback Autodesk® Material Library 2016 Succeeded
2016/5/5:17:09:57 kevindadmun KEVIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/5/5:17:09:58 kevindadmun KEVIN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/5/5:17:09:58 kevindadmun KEVIN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
What version of windows are you installing this on? More importantly, what .Net Framework version is it running?
Hello @Anonymous,
If you are using a Install Now you want to try a more effective method called Browser Download, but first uninstall the product by following the steps below.
Let us know how it turns out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
@Anonymous - These last two lines in the log file;
Means that the prerequisite is failing to install which I've seen before. There are a number of steps to take but I found this other post to be most helpful is resolving this issue.
Link edited by
Discussion_Admin
The issue has nothing to do with the 1619 error. The installation is failing due to the method the OP is using..
Mark Lancaster
& Autodesk Services MarketPlace Provider
