Installation & Licensing
3DS Max 2016 complete installation fails
4 REPLIES 4
446 Views, 4 Replies
When i try to install the programe i get this error.  I have no idea what this means.
2016/5/5:17:03:37 kevindadmun KEVIN === Setup started on KEVIN by kevindadmun ===
2016/5/5:17:03:37 kevindadmun KEVIN Path_Length: 153
2016/5/5:17:03:37 kevindadmun KEVIN Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-US
2016/5/5:17:03:37 kevindadmun KEVIN Launch
2016/5/5:17:03:37 kevindadmun KEVIN CommandLine /PK 128H1 /SN 900-49704181 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_wi_en-...
2016/5/5:17:03:37 kevindadmun KEVIN Current Directory C:\Users\KEVIND~1\AppData\Local\Temp\_AID152.tmp
2016/5/5:17:03:39 kevindadmun KEVIN === Setup ended ===
2016/5/5:17:03:38 kevindadmun KEVIN === Setup started on KEVIN by kevindadmun ===
2016/5/5:17:03:38 kevindadmun KEVIN Path_Length: 153
2016/5/5:17:03:38 kevindadmun KEVIN Current Directory C:\Users\KEVIND~1\AppData\Local\Temp\_AID152.tmp
2016/5/5:17:03:38 kevindadmun KEVIN Launch
2016/5/5:17:03:38 kevindadmun KEVIN Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUPM...
2016/5/5:17:03:38 kevindadmun KEVIN Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/SETUP_...
2016/5/5:17:03:39 kevindadmun KEVIN PageOpen LaunchDialog
2016/5/5:17:03:53 kevindadmun KEVIN PageOpen LicenseDialog
2016/5/5:17:03:53 kevindadmun KEVIN PageOpen ProductInfoDialog
2016/5/5:17:03:53 kevindadmun KEVIN PageOpen ProductSelectionDialog2
2016/5/5:17:03:58 kevindadmun KEVIN PageOpen FullProgressDialog
2016/5/5:17:03:59 kevindadmun KEVIN Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/5/5:17:03:59 kevindadmun KEVIN Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/STARTM...
2016/5/5:17:03:59 kevindadmun KEVIN Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/5/5:17:03:59 kevindadmun KEVIN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/5/5:17:05:48 kevindadmun KEVIN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/5/5:17:05:48 kevindadmun KEVIN Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/VCREDI...
2016/5/5:17:05:48 kevindadmun KEVIN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/5/5:17:06:24 kevindadmun KEVIN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/5/5:17:06:24 kevindadmun KEVIN Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/DIRECT...
2016/5/5:17:06:24 kevindadmun KEVIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/5/5:17:06:33 kevindadmun KEVIN Install DirectX® Runtime Succeeded
2016/5/5:17:06:33 kevindadmun KEVIN Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CM.tar...
2016/5/5:17:06:33 kevindadmun KEVIN Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/5/5:17:07:18 kevindadmun KEVIN Install Autodesk® Material Library 2016 Succeeded
2016/5/5:17:07:19 kevindadmun KEVIN Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILB....
2016/5/5:17:07:19 kevindadmun KEVIN Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/5/5:17:07:42 kevindadmun KEVIN Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2016/5/5:17:07:43 kevindadmun KEVIN Download Play CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/5/5:17:08:59 kevindadmun KEVIN Download Aborted CMILM http://edutrial.autodesk.com/NET16SWDLD/2016/3DSMAX/WI/{80755357-0B3F-4522-A8AF-B3E8E3EED2E0}/CMILM....
2016/5/5:17:08:59 kevindadmun KEVIN Install Autodesk® Material Library 2016 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/5/5:17:09:21 kevindadmun KEVIN Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2016/5/5:17:09:57 kevindadmun KEVIN Rollback Autodesk® Material Library 2016 Succeeded
2016/5/5:17:09:57 kevindadmun KEVIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/5/5:17:09:58 kevindadmun KEVIN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/5/5:17:09:58 kevindadmun KEVIN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
4 REPLIES 4
SMorykin
What version of windows are you installing this on?  More importantly, what .Net Framework version is it running?
If this post solves your issue or answers your question, Please select the ‘Accept as Solution’ button so other Community members may benefit. Thank you!
natasha.l
Hello @Anonymous,
If you are using a Install Now you want to try a more effective method called Browser Download, but first uninstall the product by following the steps below.
  1. Conduct a Clean Uninstall of the application & use the MSfixitTool to complete it
  2. Reboot the computer & log in as Administrator
  3. Clean out the TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Start Menu and hit Enter (Windows)
  4. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  5. Use the Browser Download Method in your Autodesk Account
Let us know how it turns out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
SMorykin
@Anonymous - These last two lines in the log file;
Means that the prerequisite is failing to install which I've seen before.  There are a number of steps to take but I found this other post to be most helpful is resolving this issue.
https://forums.autodesk.com/t5/installation-licensing/some-products-fail-to-install-result-1603/td-p/3382347
Link edited by
Discussion_Admin
Mark.Lancaster
in reply to: SMorykin
@SMorykin
The issue has nothing to do with the 1619 error.  The installation is failing due to the method the OP is using..  Smiley Very Happy
Mark Lancaster
Administrator Productivity
