Announcements
Unable to uninstall Eng Language pack
I need some help installing: autodesk product design suite ultimate 2016, in particular Inventor. Something went wrong during the initial install process and as a result I was not able to reinstall the suite because the installer said Autocad and Inventor were already installed.
After searching for a long time and deleting almost all of the registry-items naming autodesk, autocad or inventor, Autocad and Inventor were no longer installed.
The problem now is that it says the English language pack is still installed and as far as I can see it isn't.
I have already searched for solutions, but the problem is that these mostly involve microsoft FixIt, wich is not available on windows 10 (x64).
If somebody has an idea, please post the solution.
Thanks in advance
Otto
Hello jonasjonckers and welcome to the Autodesk community!
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking these pages and checking back often; we'll update with new information as our testing continues.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post, attach screen shots, or share any personal information (such as your serial #) here.
Use the Microsoft Cleanup utility for Windows 10.  I have a link to it in my signature.
Then review the verbiage below the line/above my signature and follow those steps to download and install your application.
Mark Lancaster
Hi , i have this problemalso
And waiting for better solution...
Mark.Lancaster
@Anonymous
So you're trying to install the 2016 product like the original poster?
Mark Lancaster
