公告
Unable to extract Revit part 1 or part 2 to C:/AUTODESK
不适用
709 次查看
1 条回复
1 条消息(共 2 条)
不适用
I've just downloaded Revit 2017 part 1 and Part2 (and I got a student license by email).
Whenever I double-click on Autodesk_Revit_2017_English_Win_64bit_dlm_001_002.sfx or Autodesk_Revit_2017_English_Win_64bit_dlm_002_002.sfx
I get a window asking to select a folder to extract (C:/AUTODESK)
I press Enter, but nothing happen.
The program just quits with no error message at all.
I try to install it on Windows 7 SP1 64 bit Home edition (on a Mac with BootCamp)
What should I check or search to understand why the extraction fails?
Thanks for any help
0 个赞
710 次查看
1 条回复
回复 (1)
2 条消息(共 2 条)
Mark.Lancaster
@Anonymous
Welcome to the community...
 @Alfred.NESWADBA shared the follow information with a user who was experiencing the same issue and it helped them.  You may want to give it a try..
"disable your antivirus system, make sure your destination is set to a local drive, copy the unpacked exe to a local folder, unplug or disconnect from network and start the (unpacked) exe with a right-click ==> "start as administrator".
Make sure the destination volume has enough free space."
Mark Lancaster
0 个赞
