Student autocad no longer working
Message 1 of 23
I am an Engineering Student at Mississippi State University and have been using your student autocad. Yesterday while trying to do my engineering homework on autocad it quit working. I completely removed the autocad programs from my laptop this morning and reinstalled them. I am still getting the same error message when trying to launch the program. Please help. I can not complete my homework without running autocad.
Replies (22)
Message 2 of 23
rkmcswain
Message 4 of 23
john.vellek
Hi @Anonymous,
I'm sorry your AutoCAD quit working. I suspect that the issue is really a .Net Framework issue.  What is your OS? If Windows 10, you could try resorting to a restore point.  Please take a look at the suggestions made by @rkmcswain and @pendean to see if they can get you back up and running.
John Vellek
Message 5 of 23
OS is Windows 10. This is mom now as our 17 yr old student has been trying to correct this issue since 7AM this morning. He has assignments due that can not be completed. I have not found the info posted to be helpful at all yet. Is there a support line we can call? The program and all apps were removed and it took nearly 4 hrs to reload the program. Still having the exact same error message. The student has been using the autocad fine for over a month until yesterday.
Message 6 of 23
john.vellek
Hi @Anonymous,
I am sorry that you are still struggling with this issue. The likely cause is a Windows update that occurred recently.  This might have caused a .NET error which is preventing the application from running.  One option is to try using a Restore point.  Here is a link to a third party site that shows how to do this.
Additionally, I will move this thread to Installation and Licensing as this is now an installation issue.  My associate @natasha.l is a support specialist in that forum and will look for this post.
John Vellek
Message 7 of 23
Mark.Lancaster
@Anonymous
How has the software been installed?  Install now?  Has the actual software media actually been downloaded to the machine?
Here's what I would recommend...
Perform a clean uninstall per these instructions.  Just make sure to adjust settings if you have other Autodesk products already installed/working on your machine.
Download and install per:
1.  Clean out your personal temp (%temp%) folder.  Make sure you have full admin rights, set Windows UAC to never notify and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
2. Access the Autodesk Virtual Agent and follow the download links to your product.
3. Download all of the parts (some applications only have a single part to download) for your product first. This means save each part to your hard drive.  Do not continue until all of the parts have fully downloaded.
4. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
5. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
6. Once the extraction is finished, the installation will automatically start.
7. Follow the installation steps for your product.  At this point you could cancel the installation or create a deployment.
Good luck  and report back on your progress.
Mark Lancaster
Message 8 of 23
Mark.Lancaster
@Anonymous
One more thing...
Do you have netframe 4.7 installed?  Netfrrame 4.7 is causing headaches in the Autodesk Community.
Confirm the "Version" entry in this registry entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full
If so I would recommend that you review the following articles
Article #1 - NETFRAME 4.7/Windows 7 ONLY
Article #2 - NETFRAME 4.7
Article #3 - NETFRAME 4.7
Article #4 - Windows Defender ONLY
Mark Lancaster
Message 9 of 23
rkmcswain
john.vellek wrote:
What is your OS?
John, the OP posted a full screen image. Looks like Windows 10 to me. (I'll post it inline here)
Message 10 of 23
rkmcswain
John, I don't think it's fair to blame Microsoft entirely. I'm pretty sure that developers such as Autodesk have the opportunity to test their applications with these updates before they are released to the public.
We are dealing with a similar problem that cropped up in the Win10 1703 update. Sure, Microsoft changed something in the update, but isn't it the responsibility of the application developer to ensure that the application runs on the O/S? Not the other way around.
Message 11 of 23
rkmcswain
Only 17 and already at MSU. Very nice.
Okay, on to this issue. *Generally* speaking, there is no telephone support available for Autodesk software. There are exceptions, and I don't know all of the details on student accounts. In the meantime, below are some links to the general support options.
I would look into restoring the O/S to an earlier point in time. Also, have a different user log in to the PC and see if it works under a different user account. Lastly, do you know if the assignments have to be done using "AutoCAD" (proper)?
Message 12 of 23
john.vellek
HI @rkmcswain,
Thanks for the viewpoint. From what I understand, the .Net Framework update breaks things when the pre-release of 4.6.2 is installed.  This doesn't just affect just Autodesk products but also those of Adobe and even Microsoft as well as those from other developers.  The fix, as suggested, is to remove the .Net Framework 4.7 and then remove 4.6.2. After this is done, then they can be re-installed and the applications behave properly and as designed.  This is obviously a difficult process with Windows 10 since the .Net Framework is so tightly embedded in it.
I am also aware that the .Net Framework 4.7.1 is in pre-release and apparently remedies all of the strange behavior that so many applications have been exhibiting.  I hope that this update fixes all the problems so many customers have been facing.
Thanks again for your contributions to the Community.
John Vellek
Message 13 of 23
This was not of any help. The suggestions in the article just compounded the problems for my son as it rendered ALL Microsoft office programs unusable. We worked on these issues from 7 AM until 4 pm then at 10 pm started reloading Microsoft programs for his "non engineering homework" also due this week.
Message 14 of 23
rkmcswain
This was not of any help. The suggestions in the article just compounded the problems....
@Anonymous - because of various reasons, without quoting the applicable message, we can't tell what "article" you are referring to. Multiple things were suggested in this thread, and it would be helpful for us, and future readers if we knew what did not work too. Thanks.
Message 15 of 23
I have now reloaded AutoCAD 4x on his computer. The latest reload was this morning with a whole new set of issues. This problem is only getting worse, and now the student has not been able to complete homework assignments for 3 DAYS!
Message 16 of 23
Yes Windows 10 is the OS
Message 17 of 23
Mark.Lancaster
@Anonymous
Your latest message is related to a corrupt C++ installation on your machine.
Follow the steps here.
Mark Lancaster
Message 18 of 23
Thank you. Yes he started college at 16 actually! I can not find anyway to get phone support for AutoCAD. MSU ITS just said he must bring the computer in for them to help, but he is home for fall break now. I am about at my wits end trying to help him solve these issues with AutoCAD.
Message 19 of 23
Mark.Lancaster
@Anonymous
Just to let you know..  Student/free license do not entitle you to support from Autodesk or that you have very very limited support like the forums.   The reason is because your son received the license for free.   You can always reach out to the educational support team but most likely they will just re-direct you to the forums.
Mark Lancaster
Message 20 of 23
Yes I completely understand that the student AutoCAD was given free, but in the same breath AutoCAD says they do this to help the student who is learning to be an Engineer. Once an Engineer he will pay those license fees for MANY MANY years as AutoCAD become like second nature to him while in school. I was looking for an option to even buy into some type support. The school has their own ITS dept, but for when he is not on campus he needs support. This has been nothing short of a nightmare.
The first two suggestion links in this thread only compounded the issues.
