Setup Initialization failed - Error AppHang B1
Have tried installed our IDSP 2016 deployment to 4 computers, gets stuck at initialization everytime (from network copy and local external HD copy).
Have Run as Admin, have tried installing as network admin and local admin, gets stuck.  Have tried a variety of updates and removing all updates, with and without C++ prerequisites, still fails.
AppHang81
HangSignature: 0147
Hang Type: 6144
Please help!
Rob
Otto
Hello rmounts and welcome to the Autodesk community!
It looks like you are receiving the message: "Setup initialization failed: Connection has expired". Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. The following article(s) should help you resolve the problem:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
This is a deployment install attempted from our Server and from my local external hard drive, no internet connection necessary. Even if there was, the computer is unblocked.
Rob Mounts
IT Service Support Administrator
Dawood Engineering, Inc.
rmounts@dawood.cc
Office: 724.749.4750
Rob Mounts
rmounts@dawood.cc
