Service.vbs script issue
Mohamed_Bakr
Message 1 of 21
Mohamed_Bakr
How to solve this issue? thanks.
Replies (20)
Message 2 of 21
natasha.l
Hello @Mohamed_Bakr
Does this issue just pop up or does it happen after you access something on the system?
It seems its related to files created by anti virus software. Please review this related link:
Windows Script Host error popping up, Can not find script file
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 21
natasha.l
Hello @Mohamed_Bakr
I hope you had the chance to review the information I provided. Keep me posted on the progress. 😊
Message 4 of 21
cdodge
Doh!   A quick google for 'service.vbs' shows it is part of a crack for Autodesk software.   Here is an analysis of the crack that installs service.vbs:
https://www.hybrid-analysis.com/sample/9cfdb18b13ed4f7809382f6cbd779ebdf2a35f032073b474c2f4a9bfff8ad...
Message 5 of 21
mdavis22569
Hi @Mohamed_Bakr
Were you able to get this resolved? If so, can you share how?
Mike Davis
Message 6 of 21
osama_200049
Observer
Observer
i managed to solve this problem by Making the folders Path by creating new folders and naming it just like as the path given in the error message
then creating a text file and type in it this text " Wscript.Quit " then save it in the created path the chnge the file extension ton .vbs instead of .txt
that solved my problem and let me know if this method helped you too
Best Regards,
Abdulrahman Yasser
Message 7 of 21
pitshn
Thanks Abdulrahman,
I had the same problem and your proposed solution solved it.
Message 8 of 21
mpukacka
Community Visitor
Community Visitor
I seem to have the same problem after de-installation of an older version of Autodesk. Now I'd like to instal newer version, I wonder what would be better/safer for new installation : your solution or ignoring the popping up window. I don't know what exactly the missing file was doing nor the consequences of removing it for the new installation so if you know that and could explain it ... ?
Best regards,
Margot
Message 9 of 21
cdodge
The .VBS file is not part of valid Autodesk software.  It is part of an illegal crack for Autodesk software that was previously installed.   Here is the right way to fix:
  1. Uninstall all Autodesk software, including the "Network License Manager" if installed.
  2. Download Autoruns.exe, search for "service.vbs" and uncheck it (It will prevent the VBS file from loading when you restart the computer)
  3. Re-install the Autodesk software you require from manage.autodesk.com
Message 10 of 21
mpukacka
Community Visitor
Community Visitor
That's what I was suspecting. Thank you verry much !
Message 11 of 21
jattakash123
Community Visitor
Community Visitor
tnx osama it really worked creating txt file then changing it 🙏❤️
Message 12 of 21
ldverma
Observer
Observer
I am having the same issue
I have been trying to install AutoCAD 2023 or 2024 but every time it asks my laptop to restart and after restart this error pops up
Message 13 of 21
osama_200049
Observer
Observer
You can do the same solution I mentioned above It will work ISA
Best Regards,
Abdulrahman Yasser
Message 14 of 21
ldverma
Observer
Observer
It didnot work
Message 15 of 21
ldverma
Observer
Observer
I tried that as well but i couldn't find any VBS file in autoruns.exe
Message 16 of 21
mohammed_salman_2015
Community Visitor
Community Visitor
شكرا لقد تم الحل
Message 17 of 21
mo_abbas3110
Community Visitor
Community Visitor
this works ,
Much Thanks
Message 18 of 21
sz718161419
Community Visitor
Community Visitor
Create a text file named service on your desktop and change the file suffix from.txt to.vbs. Then copy the error path to the folder in the C:\Program Files (x86)\Common Files\Autodesk Shared\Network License Manager path
Message 19 of 21
meryem_ayal
Bunu da denedim ama autoruns.exe'de herhangi bir VBS dosyası bulamadım
Message 20 of 21
meryem_ayal
Sorunu çözmüş müydünüz acaba?
