Revit installation Error 10
ssant192
Message 1 of 34
ssant192
Greetings everyone,
I am running Windows 11 on my Macbook parallel and have been attempting to install Revit 2025.
The install usually reaches around 9%, after which it randomly cancels and gives an 'Error 10".
I have tried all attempts at updating windows, running commands in terminal and speaking with Autodesk support staff who unfortunately have done little to help.
I was told by a Live Agent that my case would need to be moved to the technical department and within 2-3 days I would receive an email, which has of course not happened. they have only referred me to the forum where people have previously discussed this error, however these have not seemed to work.
If anyone has overcome this issue or a similar one, do let me know!
Thanks.
Replies (33)
Message 2 of 34
handjonathan
Hi @ssant192
Thanks a lot for posting your question to the forums!   Can you try the below?
To workaround this issue perform the following steps :
  • Restart the computer.
  • Download the latest version of the Autodesk Licensing Service for macOS and install it.
  • Retry the Autodesk installation
  • If it fails again, run the application installer from Terminal using the following command:
    • Type in Sudo Open \path to application installer and hit enter/return on keyboard.
      We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 3 of 34
ssant192
I have tried this before as stated and in terminal it tells me 'no application knows how to open URL'.
Message 4 of 34
Simon_Weel
Message 5 of 34
ssant192
Yes, this also did not help
Message 6 of 34
pendean
Community Legend
Community Legend
@ssant192 wrote:
...I was told by a Live Agent that my case would need to be moved to the technical department and within 2-3 days I would receive an email, which has of course not happened....
Keep calling. Then again. and again.
@ssant192 wrote:
...I am running Windows 11 on my Macbook parallel...
Try Parallels Support, and the Parallels User Forums in the interim.
Message 7 of 34
mdavis22569
Hi @ssant192
Sometimes the 2-3 days a bit longer. Especially around holidays.
Quick question, how did you download it for installation?  Was it the Webinstaller or was it the multiple download?
Can you try this offline installer:
P1:
https://efulfillment.autodesk.com/NetSWDLD/ODIS/prd/2025/RVT/686CE2A3-7C33-3AD5-806A-75A6E648117F/SF...
P2:
Mike Davis
Message 8 of 34
ssant192
The first link helped me and the install worked. Thank you!
Message 9 of 34
u0782123
Community Visitor
Community Visitor
Hi there, I'm also having the same issues as OP has. I tried walking through each of these steps with no success. Is there any other recommendations you fine folks have?
Message 10 of 34
pendean
Community Legend
Community Legend
Log into your PC as an all new never-seen-before user with full admin control, then try it again.
OR... try it on a second PC.
After that... you'll need to find an experienced IT group to tackle it all for you.
HTH
Message 11 of 34
juliusgUFDC7
Need help with similar problem.
I am trying to install Revit 2025 on VMware Fusion 13 Windows 11 VM and I am also getting the same Error 10.
Message 12 of 34
mchi0048F25QA
Community Visitor
Community Visitor
Hi Johnathan,
I have a Macbook pro 2023 with M2 pro chip and i cannot also install Revit as it is going up to only 9% and then saying "error 10"... I need to sort this out asap for a university assignment. How can I get help on this?
Please
Message 13 of 34
ssant192
Hey, were you able to try the links @mdavis22569  provided?
The first one worked for me
Message 14 of 34
juliusgUFDC7
I tried downloading directly from autodesk, then tried these links, but it does not work, i get the same error message.
Message 15 of 34
mdavis22569
@juliusgUFDC7    My links are giving you an issue too?
Can you try deleting all of the downloads.
Delete the C\Autodesk data, files, folders relating to Revit 2025
Clean out the %temp% folder for Windows.
Make sure the anti-Virus is off.
Please download my links again. From there, extract them to your C:\Autodesk as prompted. Let us know what happens please
Mike Davis
Message 16 of 34
aida_zs
Observer
Observer
i have the same issue and the link doesn't work any other suggestions?
Message 17 of 34
aida_zs
Observer
Observer
were you able to install it?
Message 18 of 34
juliusgUFDC7
@mdavis22569 I tried everything you suggested, but I get the same Error 10. Reinstalled windows arm several times, tried these links on freshly installed windows 11s, but it also didn't help.
I am using VMware, not Parallels, maybe that's the main issue
Message 19 of 34
mdavis22569
I would look at that .. and you pointed something out:
When you mentioned: Windows Arm....
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Revit-201...).
Mike Davis
Message 20 of 34
bim06YCY7S
Hi! The second link worked to me.
But I still need 2024 version. Do you have it ?
Thank a lot
