Revit 2024 Setup.exe not run
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 38
GHASEM_ARIYANI
hello everyone
For the 2024 version of Autodesk products, most of my students encountered installation problems. When they click on the Setup.exe file, no program is displayed for installation. I searched in Autodesk FAQ and tried the suggested solutions but none worked. Has anyone here had a similar problem and was able to fix it?
Thank you for sharing your experiences with me.
"I also uploaded a video of the problem"
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (37)
Message 2 of 38
mdavis22569
hi @GHASEM_ARIYANI
Please try going to
https://forums.autodesk.com/t5/installation-licensing/2024-product-download-links/m-p/11835996/highl...
and download the 5 part Revit 2024 here.  Don't use the SETUP.EXE one ...
Mike Davis
Message 3 of 38
GHASEM_ARIYANI
hi @mdavis22569
thanks for responding .
I downloaded it from here. These files are compressed
Therefore, they are first extracted and then installed with the installer. After extracting, no program to install is displayed. It means that the setup of Autodesk 2024 products do not work.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 4 of 38
mdavis22569
Can you share a screenshot of your C:\Autodesk folder?
Also, if your Anti-Virus turned off?
I used the installer from the link I shared .. worked for me
Mike Davis
Message 5 of 38
GHASEM_ARIYANI
Screenshot added.
This is AutoCAD software now.
None of the Autodesk 2024 programs are installed.
It means that the setup.exe software does not work.
* Yes, I disabled the antivirus.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 6 of 38
mdavis22569
Message 7 of 38
GHASEM_ARIYANI
I also wrote in the message above > > > None of the Autodesk 2024 programs are installed. It means that the setup.exe software does not work.
my pc :
Edition Windows 11 Enterprise
Version 22H2
Processor AMD Ryzen 9 7900X 12-Core Processor 4.70 GHz
Installed RAM 64.0 GB (63.1 GB usable)
System type 64-bit operating system, x64-based processor
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 8 of 38
hosseindabbagh
Community Visitor
Community Visitor
I have this problem too
Message 9 of 38
mdavis22569
So download ALL 5 of the links I shared.
Let it extract to the C:\Autodesk .. and run
Share a screenshot
Mike Davis
Message 10 of 38
thsa2501
hii,kindly make a video.i tried what you told here.
Message 11 of 38
mdavis22569
you guys make the video share your error messages etc.
I have the software installed already. No issues.
Also, make sure you have Admin rights / Anti-Virus - Firewall off.
Mike Davis
Message 12 of 38
Thanos603
I watched the original video and notice that it cuts off quickly after the preparing for installation dialog disappears.  In some cases, there is a delay between this and the actual product installation dialog.  I would wait for at least a minute or two before declaring that the install is not running.  You can also use Task Manager to verify if an Autodesk Installer process is running.
If the product installation dialog still doesn't display after a couple minutes and there is no Autodesk Installer process running, I would recommend running the AdODIS-installer.exe that resides in the ODIS folder alongside the Setup.exe.  After this component is installed, please try the product installations again.
Tony Michniewicz
Autodesk Delivery Engineer
Anthony Michniewicz
Principal QA Analyst
Message 13 of 38
mdavis22569
That's why we need the EXE's ...
Mike Davis
Message 14 of 38
ahmed_kurdi_a
same Problem I have faced while installing the InfraWorks or any other Software's.
Message 15 of 38
thsa2501
hii,thanks for the responding.still the same issue but installer running background when i check task manager.kindly give a solution to solve the problem
Message 16 of 38
GHASEM_ARIYANI
I had also attached a clip to my post...
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 17 of 38
amanihassanali
Hello Sir @mdavis22569 I faced the same problem That Mr. Gasem Faced, even the AutoCAD and Revit 2023 that were working properly before I can't make them work again after I unstained them for version 2024, same problem, when I run Sutep.exe as administrator nothing happened for both versions.
I attached video to show that.
and thanks for advance.
To Mr.Gasem @GHASEM_ARIYANI  would you please mention me if any helpful tips work?
Message 18 of 38
tldqttxd
Community Visitor
Community Visitor
Hi. you can run Autodesk License Patcher Uninstaller.exe.  Later run file steup.exe revit 2024
Message 19 of 38
amanihassanali
I tried Sir @tldqttxd , it doesn't work als
Message 20 of 38
mdavis22569
Even with my offline installer links?
Anti-Virus off?
Try a new Windows Profile for running it.
Sorry, but I don't open RAR files from the net..
Mike Davis
