Revit 2022 Error 1603 Fatal Error During Installation
gbiallas
Message 1 of 16
gbiallas
Using the new online deployment generator for Revit 2022. Deployment is created fine but when I use the batch file to install I get the dreaded yet ever present 1603 error. The log file tells me nothing except there was a fatal error during installation. What's next?
Replies (15)
Message 2 of 16
Message 3 of 16
gbiallas
Yep, none of that helped. Why is it that Autodesk's solution to any problem is always, "Burn your computer and try again"? I'm sorry but I'm not uninstalling every piece of software on my machine or de-registering everything to install a new program.
Message 4 of 16
srinivasarao.potla
Hi @gbiallas,
Thanks for the feedback.
I would like to know more about the issue. could you please share the log files?
here is the ODIS log file location C:\Users\username\AppData\Local\Autodesk\ODIS
Srinivas.
Message 5 of 16
gbiallas
I don't know which log file you want so here's all of them.
Since my last post, I've created a stripped down version of the deployment without any customization and it has been "preparing to install" for two hours now. Not sure if that's progress but it's something different.
Message 6 of 16
m_latz
Looks like the installer does not find the "J:" drive. Is this a local drive or a connected network drive ?
regards
Markus
Message 7 of 16
gbiallas
That's a network drive. I changed those locations back to the default C: drive in the modified deployment. I'm no longer getting the 1603 error but now the installation just sits in the preparation phase all day long.
Message 8 of 16
srinivasarao.potla
Hi @gbiallas
thanks for the log files.
Here is the error
2021-04-12T10:10:32.362 [Install Manager: 19160, single] [InstallManager DEBUG] [MsiHandler] [ MsiHandler::InstallUiHandler ] Returning as the error is informative Error 1327.Invalid Drive: J:\
2021-04-12T10:10:32.456 [Install Manager: 19160, single] [InstallManager INFO] [ InstallManager::HandleInstallFailure ] Failed to install Package (upi2: {AEEDBBA3-FB82-4CD4-893A-78E77BF95872} name: Revit 2022 ) Error Code: 1603 Exit Status: 2
Please check this article.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Hope this helps,
Srinivas.
Message 9 of 16
gbiallas
I figured the J: drive was part of the problem so I removed that from the deployment. All drive locations are now the default. I'm not getting the 1603 error now but I'm also not getting anything installed. The "Preparing to Install" dialog box comes up and never does anything. I've left it running all day with no result.
Message 10 of 16
gbiallas
It's definitely a network drive access issue with the computer on which I was trying to install Revit. I got this error when I ran the deployment as an administrator:
Message 11 of 16
mdavis22569
@gbiallas were you able to get this resolved?  If so, can you share how ...
best
Mike
Mike Davis
Message 12 of 16
gbiallas
It's been a while so I had to review my notes. No, I did not get this resolved. I managed to get 2022 installed on one machine using the plain install method but the deployment does not work.
Message 13 of 16
mdavis22569
Any of these help .. or are you still getting the 1603?
Mike Davis
Message 14 of 16
gbiallas
The 1603 error is gone but the deployment still doesn't work. I switched to using the install method with a custom Revit.ini file instead to get it to load on one machine. There hasn't been a big push in my office to use 2022 so I haven't been working on this.
Message 15 of 16
mdavis22569
Have you thought about submitting a case about this?
Mike Davis
Message 16 of 16
adt
I too have had the 1606 and now the 1603 after chatting with Autodesk and getting download links to the five install files.  Installing 100% locally usually fixes Revit install issues, but it didn't this time.  I might reboot, login as an admin, and try again.
