Revit 2017 installation freezes on Content Libraries
Message 1 of 15
I am trying to install Revit 2017 on my computer (a Macbook Pro with Windows 10 pro in Boot Camp), but the installation halts on the Content Libraries.
I've already deactivated Firewall, Antivírus, UAC and Smartscreen, put Autodesk.com as a safe site, downloaded the full installer using the Autodesk Virtual Agent, but the installation keeps on freezing.
And I've just reinstalled Windows from scratch, so there's nothing to clean on register or else.
What can I do?
Replies (14)
Message 2 of 15
Darin.Green
Please post the installation log files found in the %temp% directory.
If this information was helpful, please consider using the Accept Solution
Message 3 of 15
See annex
Message 4 of 15
Darin.Green
If you browse to C:\ProgramData\Autodesk\RVT 2017\Libraries are all of the files there? If so, then your Revit.ini only need to be updated.
Message 5 of 15
Darin.Green
Based on the log file, the files already exists. Even though it said "Won't Overwrite   Won't Patch" they're still there and the hashes are matching. Please post your Revit.ini file. The file is located C:\ProgramData\Autodesk\RVT 2017\UserDataCache
Message 6 of 15
Thanks. I have re-run the installation and it worked. It bypassed the content and managed to recover the system.
Message 7 of 15
josbelcm
I have the same problem, but I dont understand how to update the revit.ini, and i dont have all the content yet, I am attaching some images of this and some things that are installed.
Message 8 of 15
josbelcm
Here I attach my content libraries install.log
Message 9 of 15
Darin.Green
Please attach you Revit.ini file located C:\ProgramData\Autodesk\RVT 2017\UserDataCache
Message 10 of 15
josbelcm
The page don't let me attach the revit.ini, but here I am attaching the same file as .txt
Message 11 of 15
Darin.Green
Thanks for uploading the file. I've attached a good copy of the file for your use. You'll need to update the revit.ini file in the following locations with the one attached.
  • C:\ProgramData\Autodesk\RVT 2017\UserDataCache
  • %appdata%\Autodesk\Revit\Autodesk Revit 2017
Just copy the paths above into the address bar of Windows Explorer...
Message 12 of 15
josbelcm
Thanks, I've uptaded the revit.ini now I'm going to restart de PC and then I have to repair or reinstall the content libraries? or what is the next step?
And thank you very much for your help.
Message 13 of 15
Darin.Green
Just launch Revit again.
Message 14 of 15
josbelcm
THANK YOU A LOT! It's working perfectly.
Message 15 of 15
WalidAbyad
I'm facing the same problem with my revit library... when i downloaded revit 2017 the library files US metric, US imperial, generic, templates were all there but they were empy. so I copy and pasted them from a friends computer, however many things are still missing. should i delete every thing i copy pasted ?
NOTE: i tried updating revit content libraries but its freezing
