Renew account access
kresh.bell
kresh.bell
I renew my student account access for an additional year
After that I received an email from Autodesk
But I still have a 29-day notice of my license expiration.
How can I remove this?
Gabriel_Watson
Try to reset your license by signing out of it and signing back in with your username.
If that does not work by itself, you can force-remove the licensing information from your PC using the Autodesk Licensing Support Tool:
https://knowledge.autodesk.com/customer-service/account-management/transition-to-named-user/update-n...
Download it from here:
https://knowledge.autodesk.com/search-result/caas/downloads/content/licensing-support-tool.html
Use the following commands in CMD (command prompt) in Windows:
cd %CommonProgramFiles(x86)%\Autodesk Shared\AdskLicensing\Current\helper
AdskLicensingInstHelper change -pk ###X# -pv YEAR.#.#.X -lm USER
(use the "AdskLicensingInstHelper list" command to check if your license key and version is the same as above)
kresh.bell
I can't help myself.
But when I run the Manage license here
I see two different information for the same account
leowarren34
Hi @kresh.bell,
Which version of Inventor is this?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
kresh.bell
kresh.bell
for some reason, I don't know which one because I didn't do anything, today everything is ok.
Thanks everyone
