registration activation error 0015.111 2016
hi , i am facing below issue while activate AutoCAD 2016.
registration activation error 0015.111 2016.
appreciated your support
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
rkmcswain
1. You posted this in the DWF forum, and it will probably never get seen here. This should be in the installation and licensing forum probably.
2. You included your product serial number in a public forum, now anyone that sees it can steal it. Probably not a good idea.
Let's see if we can tag someone who can fix these items, before we move on to the actual issue here.
@Discussion_Admin
@Scooch11
@muriel.a
@natashal84
R.K. McSwain     | CADpanacea | on twitter
natasha.l
Hello @Anonymous,
The "Error (0015.111)" tends to mean a corrupted licensing information file in local client. You can try a reset of the licensing by removing the licensing information listed below.
Reset 2016 & Older Autodesk product
Conduct a Clean Uninstall & use the following steps to reset licenses for 2016 & older Autodesk products.
1. Make sure there is no Autodesk product currently running.  If there is, close the application.
2. Rename the adskflex_#######_tsf.data file to adskflex_#######_tsf.data.old   This file can be found at the following locations:
Vista or Windows 7 /8 /10
  • C:\ProgramData\FLEXnet\adskflex_########_tsf.data
  • C:\ProgramData\FLEXnet\adskflex_########_tsf.data.backup
If this does not resolve the issue, then try:
  1. Prepare to Download & Install
  2. Use Browser Download Method from Autodesk Account or via the Autodesk Virtual Agent (download all the parts)
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Hope you resolved the issue, please let us know how you resolved it.
Thank you. Smiley Happy
thanks a lot !
its resolved .
