Studing license
Studing license
Studing license
Hi there!
Im trying to activate my account of AutoCAD 2018, But its not working.
I used the trial of 30 days and tried to activate the student version after that but its not working.
Can you help me?
Im studying master architecture degree at UnB, Brazil.
Felipe Alencar.
Darin.Green
This should help get your application working. Assuming you have a valid serial number/contract.
  1. On your computer, navigate to:
    • ​​C:\ProgramData\Autodesk\CLM\LGS\<product key>_<<product version>>\
  2. Delete the LGS.data file.
  3. Navigate to
    • C:\Users\<username>\AppData\Roaming\Autodesk\
  4. Delete the ADUT folder and it's contents
  5. Start the application.
When you start the application, it will Prompt you to choose one of the following:
  • Login - 30 day trial licenses
  • Serial Number - Standalone and Single-User activations
  • Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.
NOTE: Students will always use the Serial Number option
If this information was helpful, please consider using the Accept Solution
Thanksssss!
I actually chose the "I have a serial number" option at the beggining of the program and typed the student codes autodesk gave me. It worked, I guess.
Thanks!
FA
