".NET 4.5 is not installed" error on AutoCAD install
cspencer
Message 1 of 19
cspencer
I am installing AutoCAD 2015 to a user's PC. I have not had this issue until now.
In the middle of the install I get the error message that says ".NET 4.5 is not installed. AutoCAD 2015 cannot be installed without this component. See your system administrator for more information."
I found some information on this online that talked about Windows 10 being incompatible with AutoCAD 2015, but this is Windows 7 on this PC.
I went to REGEDIT at this location: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP
This shows 4.6 as the version of .NET
Any help would be appreciated. Screen shot attached.
Canaan
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
If you read towards the bottom of that Win10 document, it also said:
"Note: the above mentioned steps can be used on Windows 7 and 8 systems to resolve the same issue with Autodesk 2015 products. "
Here is the link again https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Message 3 of 19
cspencer
Dean,
This worked. Thank you.
Canaan
Message 4 of 19
This suggestion is not working for my application. It still will not allow the download of Inventor Professional 2015 because of 4.5 not being installed. I have followed the specific directions of resetting the net frame work to 4.5 then trying to install to no avail. Is there something else I might try. I am in the middle of something critical and cannot afford the delays. I have a brand new Dell that is clean as a whistle.
Message 5 of 19
cspencer
This solution worked for me. I'm not sure what else to try. I don't know if the experts have seen your post since this has already been solved. You may want to try and create a new post asking your question so that people see it, that is, if you are still having this issue.
Canaan
Message 6 of 19
pendean
Community Legend
Community Legend
You have to install .NET4.5 (this will require you to remove all the versions installed first most likely):
You have to , find a way, there is no option around it. Take your PC to a repair shop if you don't know how. It's a requirement.
Once complete, restart Windows, log in as full administrator in Windows and get your software this way https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...
make sure your 2015 software is supported in Windows10 if that is what you have.
Message 7 of 19
I am having the same issue.  This issue is occurring within the Window 7 - 64Bit operating system
Within the registry, this pathway does not exist
Do you have another solution?
Thank you in advance.
Message 8 of 19
Hi
In my registry editor i cant find v4 in NDP. I have v3.5 and v3 only, what can i do?
Thanks!!
Message 9 of 19
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Please show a screenshot of what you see at that position in the registry-editor.
>> what can i do?
What do you want to do?
What operating system do you have, what Software and version do you want to install and what error message (exactly) do you get?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 10 of 19
Hi.. i have a question , about this step
  --> Once finished, go back in to REGEDIT and change the .NET version back to what it was.
what can i do if i did not manage to change it back to what it was. how do i know the original value of the version before i change it.
Message 11 of 19
Hi..
i cant change the value on registry
Message 12 of 19
Mark.Lancaster
@Anonymous
You have the netframe 4.7 update, which is different.  You need to review this article by @natasha.l
Mark Lancaster
Message 13 of 19
i found some answer by giving full control on user, thank you for response. 🙂
i already installed it on pc.
Message 14 of 19
my autocad 2015 isnt installing says 4.5 netframe not installed..... when i installed it using windows netframe, it says already installed.....i dont know what to do, plz help........screenshot attached thanks.....please reply asap.
Message 15 of 19
Alfred.NESWADBA
You are in the correct thread, this thread has a post which is marked as solution, this post has a link that shows you how you can solve it.
I'm quite sure that is what you should do, follow that link and it's advices ... 😉
- alfred -
Alfred NESWADBA
Message 16 of 19
prbsh2010
I tried to change the version to 4.5. But it is showing cannot edit the version. THE CURRENT VERSION IS 4.7.02053
HELP ME
Message 17 of 19
Mark.Lancaster
@prbsh2010
Welcome to the Autodesk User's Community..
Since you have netframe version 4.7 please review these articles.  You may want to review this article and use the netframe cleanup tool
Article #1 - NETFRAME 4.7/Windows 7 ONLY
Article #2 - NETFRAME 4.7
Article #3 - NETFRAME 4.7
Article #4 - Windows Defender ONLY
Mark Lancaster
Message 18 of 19
The moment you want to edit the version number from may b 4.6.0079 to 4.5...message pop up telling you that; cannot edit the version.
Message 19 of 19
I have windows 10, installed Net 4.7. the registry does not let me change anything, and I can not install the program.
