Problem with activation of AutoCAD2019 - blank page
Message 1 of 20
Hello!
This is my first entry, so please be patient.. 🙂
I try to activate a copy of AutoCAD 2019 at a users' pc. The Problem is that while trying to activate it, another window opens with no content in it. It's just a blank page - can be seen attached.
Do you guys have any idea? Also reinstalling AutoCAD and the licensing service didn't fix it.
Thank you for your help!
Greets,
Marvin
Replies (19)
Message 2 of 20
mdavis22569
HI @Anonymous
Few things to look at:
While it says Revit's it's still valid for ACAD:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/A...
https://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/Bla...
Mike Davis
Message 3 of 20
Thank you @mdavis22569,
I try to get this working.
The Problem is, that I'm not allowed to deactivate our AV-tools, so let's cross fingers to get this done!
If it doesn't work, I'll let you know.
Have a nice day! 🙂
Message 4 of 20
mdavis22569
The following needs access:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
And this might help too:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Are-th...
Mike Davis
Message 5 of 20
Now I have tried everything you guys told me, but it doesn't work properly.
The blank page still exists and the possibility to activate ACAD ist not given.
Even the mentioned Radiobuttons from other users do not apppear.
I could not disable or uninstall our enterprise grade McAfee.
Our used Firewall doesn't have any impact on the blank page as well.
The funny thing about it is, that the activation window is a html-page which refers to a program path in the local directory (c$\Program Files\Common Files\Autodesk Shared\AdLM\R15\de-DE\Webdepot\). That used html-file could be opened separately, but doesn't give the option to activate ACAD.
Greets
Marvin
Message 6 of 20
lynn_zhang
Hi @m.krenz
Sorry that you're still facing the activation issue! I've escalated the issue to Case #: 14266936 and our support team will assist you further. You will be contacted via email. Thanks for your patience!
Lynn Zhang
Message 7 of 20
lynn_zhang
Hi @m.krenz
Just wondering if you received the email from our support team in Case #: 14266936. Have you turned off your anti-virus program and tried the activation again?
Lynn Zhang
Message 8 of 20
Hey Lynn,
Of course I received your mail to the case.
I wasn't at work for the last couple days. I will try this hopefully today. My administrator told me how I could deactivate the AV, so that I hope it will work.
You will hear from me. 🙂
Best regards,
Marvin
Message 9 of 20
lynn_zhang
@m.krenz Sure, no problems. Let us know then 🙂
Lynn Zhang
Message 10 of 20
Hey guys,
Now I had the time to check whether the activation would work while our McAfee is temporarily disabled but it didn't work that well.
I'm almost lost with this PC.
Is there any other option that could help me?
Maybe assigning the license to that user which logs into his AutoDesk account?
Thank you guys for your help!
Best regards!
Message 11 of 20
mdavis22569
Might need to get a case going with Autodesk ... or get someone from the Services Marketplace to help you
https://servicesmarketplace.autodesk.com/
Mike Davis
Message 12 of 20
lynn_zhang
Hi @m.krenz
I've followed up with the technical support specialist in your Case #: 14266936 and see if he has any other ideas. Feel free to reply his email if you have any additional questions. Thanks!
Lynn Zhang
Message 13 of 20
natasha.l
Hello @Anonymous,
Thank you for posting. Have you confirmed that this download package works on another system? It may be the copy you are using, try the downloading directly from the Autodesk Account.
You can also run through the following steps below.
  1. Reboot the computer & quit any applications from Task Manager running in the background
  2. License Reset (2017 & newer products)
  3. Make sure you are properly assigned the product by the Administrator & that the Administrator has a "User" Tab
  4. The Windows profile is set to standard user & needs to be changed to Administrator
  5. Subscription Licensing Error: "Establish an Internet connection to continue"
  6. Temporarily disable security settings like Antivirus, Firewall & UAC on your system
  7.  Resetting and Changing Your Autodesk Account Password
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 14 of 20
Hello @natasha.l,
Yes, the download package does work properly on other devices. This should not be the problem.
I also tried the version which could be downloaded from the user portal, as you mentioned. 🙂
Every other step didn't affect the situation as well, so I do not know what I could do else...
Thank you for your response!
Message 15 of 20
Hey folks,
is there any option to contact a technician from autodesk?
Greets 🙂
Message 16 of 20
mdavis22569
https://knowledge.autodesk.com/contact-support
This is one way
Mike Davis
Message 17 of 20
natasha.l
Hello @Anonymous,
If all other devices are functioning properly & you can activate. It seems that the one device unable to activate is different in some way & the environment of that device is the issue (Group Policy, Admin Rights, Not a Named User).
Let us know if you make a discovery or the Activation & Registration team finds a workaround.
Message 18 of 20
Just following this thread.
I had (still have) the same problem with the 2018LT version. (Case 13727338)
2019LT also, and no solution for the moment.
Message 19 of 20
Also, the problem is, that the user we try to find a solution is almost out of the 30-day-trial. So she is no longer able to work properly.
I hope we could make that! 🙂
Message 20 of 20
Our solution for that problem was a fresh installation of the end-user-system.
