Problem to install Autocad due to missing file
Message 1 of 18
Hi. I have a problem to install Autocad 2015. Every time before finishing, it says there is a missing file... Could it be because of firewall protection? Thanks, Ben
Replies (17)
Message 2 of 18
What says missing file in the error message?. Such as Net framework or .dll file or something.
Before installing AutoCAD, Disable firewall.
Message 3 of 18
Thank you!
Message 4 of 18
I'm sorry to tell, but the solution of disabling the Firewall on my computer - didn't help!
During the installation came again the message:
.NET 4.5 is not installed. Autocad 2015 cannot be installed without this component.
See your system administrator for more information.
Please help me.
Message 5 of 18
Re: Problem to install Autocad due to missing file - NOT SOLVED YET!
Yesterday sonppw tried to help me by suggesting to DISABLE my FIREWALL.
Well, I'm sorry to tell, but this solution didn't help!
During the installation came again the message and the whole installation FAILED.
Please help me.
Message 6 of 18
rkmcswain
What O/S are you running?
If you are using a supported O/S - then avoid using the "download and install" combination method (which is the default). Follow these links to direct downloads: 2017 and earlier, or here for 2018. After you download the required files, if you are not sure what to do, click here for help.
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 18
Mark.Lancaster
@Anonymous
Please review this information and the solutions it provides.  Next follow @rkmcswain information for installing.
Mark Lancaster
Message 8 of 18
My operating system is Windows 7 (I didn't like version 10).
Message 9 of 18
Message 10 of 18
Mark.Lancaster
@Anonymous wrote:
What questions do you have?
Mark Lancaster
Message 11 of 18
rkmcswain
 The original thread is here. Hopefully the mods will merge them together.
Message 12 of 18
Sorry - but how can I change default action in Download process in Windows 7?
Message 13 of 18
Could you please tell me, very specifically, how could I solve it? So far, the answers were very general. Thanks
Message 14 of 18
Mark.Lancaster
@Anonymous
I sent you a link in how to resolve the issue of not having netframe 4.5 installed on your machine.  Have you followed those steps?  If you're not sure how to handle this or don't want to..  I would recommend taking your machine to a place that troubleshoots computers or perhaps you have a family and/or friend that can assist you.  In addition I don't know where you are at this posint since we have already provided info to you.  What did you try and etc...  Smiley Wink
Mark Lancaster
Message 15 of 18
Thanks Mark.
The only advice I could guess that is related with my problem, is - "Before downloading anything, wipe your system clean of any existing Autodesk program files."
Well, it's a little bit complicated because I have also REVIT on my computer. I wouldn't want to uninstall it.
So, the last relevant advice is...
"Delete the file you downloaded.
Go to Start > Accessories > System Tools > Disc Cleanup and run that utility to clear your temp files, etc.
Reboot your machine.
Go to your country's main Autodesk website and download the trial version of the software.
Install the product.
Return to the Education Community to obtain your product key and serial number."
I doubt if it'll help because I've already done so recently with CClean, but I'll give it a chance.
ONE QUESTION: I guess it has nothing to do with the Autocad version I chose to use, I mean - the year (2015). Isn't it so?
Thanks anyway.
Message 16 of 18
Sorry, I'm too late due to a personal issue.
I don't know your OS.
If your OS is Window 10, You need recently Window update, and then Your computer will be installed Net Framework 4.7 automatically.
So Try again installing AutoCAD, But you still get the error message, You have to edit net framework version in the Registry.
This link helps you how to edit net framework version in the registry.
Window 10 does not support AutoCAD 2015 as perfectly that I heard, I don't know what it means.
If your OS is Window 7 or 8.1, You need to install Net framework 4.5 at here.
If you are already installed Net framework 4.5 on your computer, I recommend you to install 2015 hotfix that it can fix Net Framework 4.5 issue from here
Message 17 of 18
Mark.Lancaster
There's two conversation going on about this subject..  Its going to get confusing really quick if the conversation start to head in opposite directions.
Mark Lancaster
Message 18 of 18
Mark.Lancaster
@Anonymous
Where are you getting this advice to wipe your system?   Have you followed the steps about the netframe?  I can't afford to keep going back and forth on this subject and asking you the same question over and over...  Smiley Wink
Mark Lancaster
