NLM-client not using BDSP, only AEC.
thomas_aardal
Message 1 of 11
thomas_aardal
Hello
I need some help with this strange situation.
One of my costumers klients is not able to obtain license from the server.
The costumers license file contain 1 seat AEC collection and 3 Seats BDSP.
When starting Revit or Autocad 2018 on the client (Eva@SHARK114)  we get the error (-15.570.0)
The status inquiry in LMtools is showing that the 1 AEC is OUT, but all 3 BDSP is available.
I can see from the flexnet logfile that the loan is only trying to access the AEC license:
 8:47:39 (adskflex) DENIED: "86815AECCOL_T_F" Eva@SHARK114  (Licensed number of users already reached. (-4,342))
 8:47:39 (adskflex) DENIED: "86917RVT_2018_0F" Eva@SHARK114  (Licensed number of users already reached. (-4,342))
 9:11:41 (adskflex) DENIED: "86815AECCOL_T_F" Eva@SHARK114  (Licensed number of users already reached. (-4,342))
 9:11:41 (adskflex) DENIED: "86830ACD_2018_0F" Eva@SHARK114  (Licensed number of users already reached. (-4,342))
We started Revit 2018 on another client (Kari@SHARK115 ) and it checked out 1 of the BDSP licenses (after first trying the AEC because cascading):
 9:45:13 (adskflex) DENIED: "86815AECCOL_T_F" Kari@SHARK115  (Licensed number of users already reached. (-4,342))
 9:45:13 (adskflex) DENIED: "86917RVT_2018_0F" Kari@SHARK115  (Licensed number of users already reached. (-4,342))
 9:45:13 (adskflex) OUT: "85787BDSPRM_F" Kari@SHARK115
 9:45:13 (adskflex) OUT: "86903BDSPRM_2018_0F" Kari@SHARK115
There is no .opt present
There is no system variables on the clients.
The license file is generated for the 2019 versjon.
Flexnet is updated to 11.14
I have never had this issue before. Could it be a bug?
What is seperating the two clients? Why does it not "see" the available BDSP?
Is it the Vendor deamon or the checkout request itself that is asking for the wrong license?
If the AEC license is available the client will use this, but because of cascading it never is.....
Replies (10)
Message 2 of 11
Mark.Lancaster
@thomas_aardal
I would start here https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-15-570-0-A-valid-l... but also provided the entire debug log file that's specified in the config service tab of lmtools and not bits and pieces.
Mark Lancaster
Message 3 of 11
thomas_aardal
Im sorry, here is the full log:
10:00:26 (lmgrd) -----------------------------------------------
10:00:26 (lmgrd) Please Note:
10:00:26 (lmgrd)
10:00:26 (lmgrd) This log is intended for debug purposes only.
10:00:26 (lmgrd) In order to capture accurate license
10:00:26 (lmgrd) usage data into an organized repository,
10:00:26 (lmgrd) please enable report logging. Use Flexera Software LLC's
10:00:26 (lmgrd) software license administration solution,
10:00:26 (lmgrd) FlexNet Manager, to readily gain visibility
10:00:26 (lmgrd) into license usage data and to create
10:00:26 (lmgrd) insightful reports on critical information like
10:00:26 (lmgrd) license availability and usage. FlexNet Manager
10:00:26 (lmgrd) can be fully automated to run these reports on
10:00:26 (lmgrd) schedule and can be used to track license
10:00:26 (lmgrd) servers and usage across a heterogeneous
10:00:26 (lmgrd) network of servers including Windows NT, Linux
10:00:26 (lmgrd) and UNIX.
10:00:26 (lmgrd)
10:00:26 (lmgrd)
10:00:26 (lmgrd)
10:00:26 (lmgrd) Server's System Date and Time: Wed Sep 12 2018 10:00:26 W. Europe Daylight Time
10:00:26 (lmgrd) pid 18420
10:00:26 (lmgrd) SLOG: Summary LOG statistics is enabled.
10:00:26 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:00:29 (lmgrd) Done rereading
10:00:29 (lmgrd) FlexNet Licensing (v11.14.1.3 build 212549 x64_n6) started on SERVER (IBM PC) (9/12/2018)
10:00:29 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
10:00:29 (lmgrd) World Wide Web: http://www.flexerasoftware.com
10:00:29 (lmgrd) License file(s): C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic
10:00:29 (lmgrd) lmgrd tcp-port 27000
10:00:29 (lmgrd) (@lmgrd-SLOG@) ===============================================
10:00:29 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
10:00:29 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Sep 12 2018 10:00:29 W. Europe Daylight Time
10:00:29 (lmgrd) (@lmgrd-SLOG@) PID: 18420
10:00:29 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
10:00:29 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
10:00:29 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
10:00:29 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
10:00:29 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
10:00:29 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
10:00:29 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic -l C:\Autodesk\Network License Manager\debug.log -z -s
10:00:29 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic
10:00:29 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
10:00:29 (lmgrd) Starting vendor daemons ...
10:00:29 (lmgrd) Starting vendor daemon at port 2080
10:00:29 (lmgrd) Using vendor daemon port 2080 specified in license file
10:00:29 (lmgrd) Started adskflex (pid 18888)
10:00:29 (adskflex) Unable to initialize access to trusted storage: 1
10:00:29 (adskflex) FlexNet Licensing version v11.14.1.3 build 212549 x64_n6
10:00:29 (adskflex) SLOG: Summary LOG statistics is enabled.
10:00:29 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
10:00:29 (adskflex) SLOG: VM Status: 0
10:00:34 (adskflex) Server started on SERVER for:
10:00:34 (adskflex) 85787BDSPRM_F (consisting of: 87142BDSPRM_2019_0F
10:00:34 (adskflex) 86903BDSPRM_2018_0F 86696BDSPRM_2017_0F 86451BDSPRM_2016_0F
10:00:34 (adskflex) 86238BDSPRM_2015_0F 86071BDSPRM_2014_0F)
10:00:34 (adskflex) 86815AECCOL_T_F (consisting of: 87084ACD_2019_0F
10:00:34 (adskflex) 86830ACD_2018_0F 86604ACD_2017_0F 86445ACD_2016_0F
10:00:34 (adskflex) 86295ACD_2015_0F 87087ARCHDESK_2019_0F 86856ARCHDESK_2018_0F
10:00:34 (adskflex) 86480ARCHDESK_2017_0F 86480ARCHDESK_2016_0F 86288ARCHDESK_2015_0F
10:00:34 (adskflex) 87140CIV3D_2019_0F 86893CIV3D_2018_0F 86718CIV3D_2017_0F
10:00:34 (adskflex) 86514CIV3D_2016_0F 86354CIV3D_2015_0F 87088ACAD_E_2019_0F
10:00:34 (adskflex) 86635ACAD_E_2018_0F 86635ACAD_E_2017_0F 86481ACAD_E_2016_0F
10:00:34 (adskflex) 86290ACAD_E_2015_0F 87091MAP_2019_0F 86866MAP_2018_0F
10:00:34 (adskflex) 86719MAP_2017_0F 86517MAP_2016_0F 86355MAP_2015_0F
10:00:34 (adskflex) 87090BLDSYS_2019_0F 86855BLDSYS_2018_0F 86631BLDSYS_2017_0F
10:00:34 (adskflex) 86479BLDSYS_2016_0F 86292BLDSYS_2015_0F 86648PNID_2017_0F
10:00:34 (adskflex) 86517PNID_2016_0F 86301PNID_2015_0F 87153PLNT3D_2019_0F
10:00:34 (adskflex) 86894PLNT3D_2018_0F 86650PLNT3D_2017_0F 86517PLNT3D_2016_0F
10:00:34 (adskflex) 86296PLNT3D_2015_0F 87086ARDES_2019_0F 86832ARDES_2018_0F
10:00:34 (adskflex) 86606ARDES_2017_0F 86474ARDES_2016_0F 86294ARDES_2015_0F
10:00:34 (adskflex) 86720UTLDESN_2017_0F 86517UTLDESN_2016_0F 86356UTLDESN_2015_0F
10:00:34 (adskflex) 87149RVT_2019_0F 86917RVT_2018_0F 86706RVT_2017_0F
10:00:34 (adskflex) 86453RVT_2016_0F 86273RVT_2015_0F 86454REVIT_2016_0F
10:00:34 (adskflex) 86274REVIT_2015_0F 86456RVTMPB_2016_0F 86276RVTMPB_2015_0F
10:00:34 (adskflex) 86457REVITST_2016_0F 86277REVITST_2015_0F 87176NAVMAN_2019_0F
10:00:34 (adskflex) 86998NAVMAN_2018_0F 86766NAVMAN_2017_0F 86534NAVMAN_2016_0F
10:00:34 (adskflex) 86350NAVMAN_2015_0F 87152VEHTRK_2019_0F 86920VEHTRK_2018_0F
10:00:34 (adskflex) 86726VEHTRK_2017_0F 86565VEHTRK_2016_0F 86388VEHTRK_2015_0F
10:00:34 (adskflex) 870723DSMAX_2019_0F 868333DSMAX_2018_0F 866333DSMAX_2017_0F
10:00:34 (adskflex) 864713DSMAX_2016_0F 862623DSMAX_2015_0F 86263MAXDES_2015_0F
10:00:34 (adskflex) 87093RECAP_2019_0F 86984RECAP_2018_0F 86747RECAP_2017_0F
10:00:34 (adskflex) 86538RECAP_2016_0F 86402RECAP_2015_0F 87096ADSTPR_2019_0F
10:00:34 (adskflex) 86857ADSTPR_2018_0F 86612ADSTPR_2017_0F 86507ADSTPR_2016_0F
10:00:34 (adskflex) 86490ADSTPR_2015_1F 86375ADSTPR_2015_0F 87166CADMEP_2019_0F
10:00:34 (adskflex) 86938CADMEP_2018_0F 86777CADMEP_2017_0F 86519CADMEP_2016_0F
10:00:34 (adskflex) 86281CADMEP_2015_0F 87170RSAPRO_2019_0F 86941RSAPRO_2018_0F
10:00:34 (adskflex) 86659RSAPRO_2017_0F 86439RSAPRO_2016_0F 86297RSAPRO_2015_0F
10:00:34 (adskflex) 86937LIVE_2018_0F 86822DYNSTD_2017_0F 86643DYNSTD_2016_0F
10:00:34 (adskflex) 87151SBRDES_2019_0F 86919SBRDES_2018_0F 86792SBRDES_2017_0F
10:00:34 (adskflex) 86328SBRDES_2016_0F 87089AMECH_PP_2019_0F 86839AMECH_PP_2018_0F
10:00:34 (adskflex) 86627AMECH_PP_2017_0F 86478AMECH_PP_2016_0F 86279AMECH_PP_2015_0F)
10:00:34 (adskflex) EXTERNAL FILTERS are OFF
10:00:34 (lmgrd) adskflex using TCP-port 2080
10:00:34 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
10:00:34 (adskflex) SLOG: TS update poll interval is 600 seconds.
10:00:34 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
10:00:34 (adskflex) (@adskflex-SLOG@) ===============================================
10:00:34 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
10:00:34 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
10:00:34 (adskflex) (@adskflex-SLOG@) Start-Date: Wed Sep 12 2018 10:00:34 W. Europe Daylight Time
10:00:34 (adskflex) (@adskflex-SLOG@) PID: 18888
10:00:34 (adskflex) (@adskflex-SLOG@) VD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
10:00:34 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
10:00:34 (adskflex) (@adskflex-SLOG@) Options file used: None
10:00:34 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
10:00:34 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
10:00:34 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
10:00:34 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
10:00:34 (adskflex) (@adskflex-SLOG@) === Network Info ===
10:00:34 (adskflex) (@adskflex-SLOG@) Listening port: 2080
10:00:34 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
10:00:34 (adskflex) (@adskflex-SLOG@) === Host Info ===
10:00:34 (adskflex) (@adskflex-SLOG@) Host used in license file: SERVER
10:00:34 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: Not determined - treat as Physical
10:00:39 (lmgrd) Rereading license file... Requested from egil@SERVER
10:00:39 (adskflex) TCP_NODELAY NOT enabled
10:00:39 (adskflex) Rereading license file...
10:00:39 (lmgrd) Done rereading
10:00:39 (lmgrd) ...Finished rereading
10:00:46 (adskflex) Server started on SERVER for:
10:00:46 (adskflex) 85787BDSPRM_F (consisting of: 87142BDSPRM_2019_0F
10:00:46 (adskflex) 86903BDSPRM_2018_0F 86696BDSPRM_2017_0F 86451BDSPRM_2016_0F
10:00:46 (adskflex) 86238BDSPRM_2015_0F 86071BDSPRM_2014_0F)
10:00:46 (adskflex) 86815AECCOL_T_F (consisting of: 87084ACD_2019_0F
10:00:46 (adskflex) 86830ACD_2018_0F 86604ACD_2017_0F 86445ACD_2016_0F
10:00:46 (adskflex) 86295ACD_2015_0F 87087ARCHDESK_2019_0F 86856ARCHDESK_2018_0F
10:00:46 (adskflex) 86480ARCHDESK_2017_0F 86480ARCHDESK_2016_0F 86288ARCHDESK_2015_0F
10:00:46 (adskflex) 87140CIV3D_2019_0F 86893CIV3D_2018_0F 86718CIV3D_2017_0F
10:00:46 (adskflex) 86514CIV3D_2016_0F 86354CIV3D_2015_0F 87088ACAD_E_2019_0F
10:00:46 (adskflex) 86635ACAD_E_2018_0F 86635ACAD_E_2017_0F 86481ACAD_E_2016_0F
10:00:46 (adskflex) 86290ACAD_E_2015_0F 87091MAP_2019_0F 86866MAP_2018_0F
10:00:46 (adskflex) 86719MAP_2017_0F 86517MAP_2016_0F 86355MAP_2015_0F
10:00:46 (adskflex) 87090BLDSYS_2019_0F 86855BLDSYS_2018_0F 86631BLDSYS_2017_0F
10:00:46 (adskflex) 86479BLDSYS_2016_0F 86292BLDSYS_2015_0F 86648PNID_2017_0F
10:00:46 (adskflex) 86517PNID_2016_0F 86301PNID_2015_0F 87153PLNT3D_2019_0F
10:00:46 (adskflex) 86894PLNT3D_2018_0F 86650PLNT3D_2017_0F 86517PLNT3D_2016_0F
10:00:46 (adskflex) 86296PLNT3D_2015_0F 87086ARDES_2019_0F 86832ARDES_2018_0F
10:00:46 (adskflex) 86606ARDES_2017_0F 86474ARDES_2016_0F 86294ARDES_2015_0F
10:00:46 (adskflex) 86720UTLDESN_2017_0F 86517UTLDESN_2016_0F 86356UTLDESN_2015_0F
10:00:46 (adskflex) 87149RVT_2019_0F 86917RVT_2018_0F 86706RVT_2017_0F
10:00:46 (adskflex) 86453RVT_2016_0F 86273RVT_2015_0F 86454REVIT_2016_0F
10:00:46 (adskflex) 86274REVIT_2015_0F 86456RVTMPB_2016_0F 86276RVTMPB_2015_0F
10:00:46 (adskflex) 86457REVITST_2016_0F 86277REVITST_2015_0F 87176NAVMAN_2019_0F
10:00:46 (adskflex) 86998NAVMAN_2018_0F 86766NAVMAN_2017_0F 86534NAVMAN_2016_0F
10:00:46 (adskflex) 86350NAVMAN_2015_0F 87152VEHTRK_2019_0F 86920VEHTRK_2018_0F
10:00:46 (adskflex) 86726VEHTRK_2017_0F 86565VEHTRK_2016_0F 86388VEHTRK_2015_0F
10:00:46 (adskflex) 870723DSMAX_2019_0F 868333DSMAX_2018_0F 866333DSMAX_2017_0F
10:00:46 (adskflex) 864713DSMAX_2016_0F 862623DSMAX_2015_0F 86263MAXDES_2015_0F
10:00:46 (adskflex) 87093RECAP_2019_0F 86984RECAP_2018_0F 86747RECAP_2017_0F
10:00:46 (adskflex) 86538RECAP_2016_0F 86402RECAP_2015_0F 87096ADSTPR_2019_0F
10:00:46 (adskflex) 86857ADSTPR_2018_0F 86612ADSTPR_2017_0F 86507ADSTPR_2016_0F
10:00:46 (adskflex) 86490ADSTPR_2015_1F 86375ADSTPR_2015_0F 87166CADMEP_2019_0F
10:00:46 (adskflex) 86938CADMEP_2018_0F 86777CADMEP_2017_0F 86519CADMEP_2016_0F
10:00:46 (adskflex) 86281CADMEP_2015_0F 87170RSAPRO_2019_0F 86941RSAPRO_2018_0F
10:00:46 (adskflex) 86659RSAPRO_2017_0F 86439RSAPRO_2016_0F 86297RSAPRO_2015_0F
10:00:46 (adskflex) 86937LIVE_2018_0F 86822DYNSTD_2017_0F 86643DYNSTD_2016_0F
10:00:46 (adskflex) 87151SBRDES_2019_0F 86919SBRDES_2018_0F 86792SBRDES_2017_0F
10:00:46 (adskflex) 86328SBRDES_2016_0F 87089AMECH_PP_2019_0F 86839AMECH_PP_2018_0F
10:00:46 (adskflex) 86627AMECH_PP_2017_0F 86478AMECH_PP_2016_0F 86279AMECH_PP_2015_0F)
10:00:46 (adskflex) Updating feature 85787BDSPRM_F
10:00:46 (adskflex) Updating feature 86815AECCOL_T_F
10:00:46 (adskflex) Updating feature 87084ACD_2019_0F
10:00:46 (adskflex) Updating feature 86830ACD_2018_0F
10:00:46 (adskflex) Updating feature 86604ACD_2017_0F
10:00:46 (adskflex) Updating feature 86445ACD_2016_0F
10:00:46 (adskflex) Updating feature 86295ACD_2015_0F
10:00:46 (adskflex) Updating feature 87087ARCHDESK_2019_0F
10:00:46 (adskflex) Updating feature 86856ARCHDESK_2018_0F
10:00:46 (adskflex) Updating feature 86480ARCHDESK_2017_0F
10:00:46 (adskflex) Updating feature 86480ARCHDESK_2016_0F
10:00:46 (adskflex) Updating feature 86288ARCHDESK_2015_0F
10:00:46 (adskflex) Updating feature 87140CIV3D_2019_0F
10:00:46 (adskflex) Updating feature 86893CIV3D_2018_0F
10:00:46 (adskflex) Updating feature 86718CIV3D_2017_0F
10:00:46 (adskflex) Updating feature 86514CIV3D_2016_0F
10:00:46 (adskflex) Updating feature 86354CIV3D_2015_0F
10:00:46 (adskflex) Updating feature 87088ACAD_E_2019_0F
10:00:46 (adskflex) Updating feature 86635ACAD_E_2018_0F
10:00:46 (adskflex) Updating feature 86635ACAD_E_2017_0F
10:00:46 (adskflex) Updating feature 86481ACAD_E_2016_0F
10:00:46 (adskflex) Updating feature 86290ACAD_E_2015_0F
10:00:46 (adskflex) Updating feature 87091MAP_2019_0F
10:00:46 (adskflex) Updating feature 86866MAP_2018_0F
10:00:46 (adskflex) Updating feature 86719MAP_2017_0F
10:00:46 (adskflex) Updating feature 86517MAP_2016_0F
10:00:46 (adskflex) Updating feature 86355MAP_2015_0F
10:00:46 (adskflex) Updating feature 87090BLDSYS_2019_0F
10:00:46 (adskflex) Updating feature 86855BLDSYS_2018_0F
10:00:46 (adskflex) Updating feature 86631BLDSYS_2017_0F
10:00:46 (adskflex) Updating feature 86479BLDSYS_2016_0F
10:00:46 (adskflex) Updating feature 86292BLDSYS_2015_0F
10:00:46 (adskflex) Updating feature 86648PNID_2017_0F
10:00:46 (adskflex) Updating feature 86517PNID_2016_0F
10:00:46 (adskflex) Updating feature 86301PNID_2015_0F
10:00:46 (adskflex) Updating feature 87153PLNT3D_2019_0F
10:00:46 (adskflex) Updating feature 86894PLNT3D_2018_0F
10:00:46 (adskflex) Updating feature 86650PLNT3D_2017_0F
10:00:46 (adskflex) Updating feature 86517PLNT3D_2016_0F
10:00:46 (adskflex) Updating feature 86296PLNT3D_2015_0F
10:00:46 (adskflex) Updating feature 87086ARDES_2019_0F
10:00:46 (adskflex) Updating feature 86832ARDES_2018_0F
10:00:46 (adskflex) Updating feature 86606ARDES_2017_0F
10:00:46 (adskflex) Updating feature 86474ARDES_2016_0F
10:00:46 (adskflex) Updating feature 86294ARDES_2015_0F
10:00:46 (adskflex) Updating feature 86720UTLDESN_2017_0F
10:00:46 (adskflex) Updating feature 86517UTLDESN_2016_0F
10:00:46 (adskflex) Updating feature 86356UTLDESN_2015_0F
10:00:46 (adskflex) Updating feature 87149RVT_2019_0F
10:00:46 (adskflex) Updating feature 86917RVT_2018_0F
10:00:46 (adskflex) Updating feature 86706RVT_2017_0F
10:00:46 (adskflex) Updating feature 86453RVT_2016_0F
10:00:46 (adskflex) Updating feature 86273RVT_2015_0F
10:00:46 (adskflex) Updating feature 86454REVIT_2016_0F
10:00:46 (adskflex) Updating feature 86274REVIT_2015_0F
10:00:46 (adskflex) Updating feature 86456RVTMPB_2016_0F
10:00:46 (adskflex) Updating feature 86276RVTMPB_2015_0F
10:00:46 (adskflex) Updating feature 86457REVITST_2016_0F
10:00:46 (adskflex) Updating feature 86277REVITST_2015_0F
10:00:46 (adskflex) Updating feature 87176NAVMAN_2019_0F
10:00:46 (adskflex) Updating feature 86998NAVMAN_2018_0F
10:00:46 (adskflex) Updating feature 86766NAVMAN_2017_0F
10:00:46 (adskflex) Updating feature 86534NAVMAN_2016_0F
10:00:46 (adskflex) Updating feature 86350NAVMAN_2015_0F
10:00:46 (adskflex) Updating feature 87152VEHTRK_2019_0F
10:00:46 (adskflex) Updating feature 86920VEHTRK_2018_0F
10:00:46 (adskflex) Updating feature 86726VEHTRK_2017_0F
10:00:46 (adskflex) Updating feature 86565VEHTRK_2016_0F
10:00:46 (adskflex) Updating feature 86388VEHTRK_2015_0F
10:00:46 (adskflex) Updating feature 870723DSMAX_2019_0F
10:00:46 (adskflex) Updating feature 868333DSMAX_2018_0F
10:00:46 (adskflex) Updating feature 866333DSMAX_2017_0F
10:00:46 (adskflex) Updating feature 864713DSMAX_2016_0F
10:00:46 (adskflex) Updating feature 862623DSMAX_2015_0F
10:00:46 (adskflex) Updating feature 86263MAXDES_2015_0F
10:00:46 (adskflex) Updating feature 87093RECAP_2019_0F
10:00:46 (adskflex) Updating feature 86984RECAP_2018_0F
10:00:46 (adskflex) Updating feature 86747RECAP_2017_0F
10:00:46 (adskflex) Updating feature 86538RECAP_2016_0F
10:00:46 (adskflex) Updating feature 86402RECAP_2015_0F
10:00:46 (adskflex) Updating feature 87096ADSTPR_2019_0F
10:00:46 (adskflex) Updating feature 86857ADSTPR_2018_0F
10:00:46 (adskflex) Updating feature 86612ADSTPR_2017_0F
10:00:46 (adskflex) Updating feature 86507ADSTPR_2016_0F
10:00:46 (adskflex) Updating feature 86490ADSTPR_2015_1F
10:00:46 (adskflex) Updating feature 86375ADSTPR_2015_0F
10:00:46 (adskflex) Updating feature 87166CADMEP_2019_0F
10:00:46 (adskflex) Updating feature 86938CADMEP_2018_0F
10:00:46 (adskflex) Updating feature 86777CADMEP_2017_0F
10:00:46 (adskflex) Updating feature 86519CADMEP_2016_0F
10:00:46 (adskflex) Updating feature 86281CADMEP_2015_0F
10:00:46 (adskflex) Updating feature 87170RSAPRO_2019_0F
10:00:46 (adskflex) Updating feature 86941RSAPRO_2018_0F
10:00:46 (adskflex) Updating feature 86659RSAPRO_2017_0F
10:00:46 (adskflex) Updating feature 86439RSAPRO_2016_0F
10:00:46 (adskflex) Updating feature 86297RSAPRO_2015_0F
10:00:46 (adskflex) Updating feature 86937LIVE_2018_0F
10:00:46 (adskflex) Updating feature 86822DYNSTD_2017_0F
10:00:46 (adskflex) Updating feature 86643DYNSTD_2016_0F
10:00:46 (adskflex) Updating feature 87151SBRDES_2019_0F
10:00:46 (adskflex) Updating feature 86919SBRDES_2018_0F
10:00:46 (adskflex) Updating feature 86792SBRDES_2017_0F
10:00:46 (adskflex) Updating feature 86328SBRDES_2016_0F
10:00:46 (adskflex) Updating feature 87089AMECH_PP_2019_0F
10:00:46 (adskflex) Updating feature 86839AMECH_PP_2018_0F
10:00:46 (adskflex) Updating feature 86627AMECH_PP_2017_0F
10:00:46 (adskflex) Updating feature 86478AMECH_PP_2016_0F
10:00:46 (adskflex) Updating feature 86279AMECH_PP_2015_0F
10:00:46 (adskflex) Updating feature 87142BDSPRM_2019_0F
10:00:46 (adskflex) Updating feature 86903BDSPRM_2018_0F
10:00:46 (adskflex) Updating feature 86696BDSPRM_2017_0F
10:00:46 (adskflex) Updating feature 86451BDSPRM_2016_0F
10:00:46 (adskflex) Updating feature 86238BDSPRM_2015_0F
10:00:46 (adskflex) Updating feature 86071BDSPRM_2014_0F
10:00:46 (adskflex) Rereading options file...
10:00:46 (adskflex) Client Authentication Initiated...
10:00:46 (adskflex) (@adskflex-SLOG@) ===============================================
10:00:46 (adskflex) (@adskflex-SLOG@) === Reread Info ===
10:00:46 (adskflex) (@adskflex-SLOG@) Reread time: Wed Sep 12 2018 10:00:46 W. Europe Daylight Time
10:00:46 (adskflex) (@adskflex-SLOG@) Number of rereads since vendor daemon startup: 1
10:00:46 (adskflex) (@adskflex-SLOG@) Reread mechanism: Manual
10:00:46 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
10:00:46 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
10:00:46 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
10:00:46 (adskflex) (@adskflex-SLOG@) Options file used: None
10:00:46 (adskflex) (@adskflex-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic
10:00:46 (adskflex) ...Finished rereading
10:01:43 (adskflex) OUT: "86815AECCOL_T_F" Eli@SHARK123
10:01:43 (adskflex) OUT: "86917RVT_2018_0F" Eli@SHARK123
10:01:54 (adskflex) DENIED: "86815AECCOL_T_F" Eva@SHARK114 (Licensed number of users already reached. (-4,342))
10:01:54 (adskflex) DENIED: "86830ACD_2018_0F" Eva@SHARK114 (Licensed number of users already reached. (-4,342))
10:29:26 (adskflex) DENIED: "86815AECCOL_T_F" Kari@SHARK115 (Licensed number of users already reached. (-4,342))
10:29:26 (adskflex) DENIED: "86830ACD_2018_0F" Kari@SHARK115 (Licensed number of users already reached. (-4,342))
10:29:26 (adskflex) DENIED: "86839AMECH_PP_2018_0F" Kari@SHARK115 (Licensed number of users already reached. (-4,342))
10:29:26 (adskflex) DENIED: "86894PLNT3D_2018_0F" Kari@SHARK115 (Licensed number of users already reached. (-4,342))
10:29:26 (adskflex) DENIED: "86857ADSTPR_2018_0F" Kari@SHARK115 (Licensed number of users already reached. (-4,342))
10:29:26 (adskflex) OUT: "85787BDSPRM_F" Kari@SHARK115
10:29:26 (adskflex) OUT: "86903BDSPRM_2018_0F" Kari@SHARK115
10:30:27 (adskflex) DENIED: "86815AECCOL_T_F" Eva@SHARK114 (Licensed number of users already reached. (-4,342))
10:30:27 (adskflex) DENIED: "86830ACD_2018_0F" Eva@SHARK114 (Licensed number of users already reached. (-4,342))
Message 4 of 11
Mark.Lancaster
@thomas_aardal
Looking at the logs I see what you're saying..  However I noticed you still have the 2014 version for your building designs suite and I'm wondering if your license file is not properly formatted.  However don't share it here since it contains sensitive info.  If you want to talk about sharing it, please private message me and we can take this topic off-line.
Update:  However I will also tag @TravisNave for his input.  Travis, user is launch AutoCAD 2018 and it tries to pull from their collection license (which it should, term or perpetual) but collection license is already in use but it never tries to pull from the suite license and they have no option file.
Mark Lancaster
Message 5 of 11
thomas_aardal
I would like for you to take a look at the license file, Mark.
Will send you a pm, thanks!
I think its strange that the other clients pull form the BDSP just fine. Almost like its "invisible" for the one client.
Message 6 of 11
Mark.Lancaster
@thomas_aardal
I will also follow up with a PM too..
But let's do this..
On the user's machine that is unable to obtain a license or use the suite perpetual, go to this folder C:\ProgramData\Autodesk\AdLM and move the CascadeInfo.cas to another location.
In addition if not already apply this hotfix https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-License-Service...
Try launching the product again and see if the user is able to obtain a license.
Mark Lancaster
Message 7 of 11
thomas_aardal
I connected to the costumer and all the licenses was available. So i asked someone to start Revit to pull the AEC license, so the scenario for testing this client was right.
I was shocked when the other client takes the BDSP! Does not make sense, the AEC was available. So i was not able to test any further...
What is going on here?
8:36:45 (lmgrd) -----------------------------------------------
8:36:45 (lmgrd) Please Note:
8:36:45 (lmgrd)
8:36:45 (lmgrd) This log is intended for debug purposes only.
8:36:45 (lmgrd) In order to capture accurate license
8:36:45 (lmgrd) usage data into an organized repository,
8:36:45 (lmgrd) please enable report logging. Use Flexera Software LLC's
8:36:45 (lmgrd) software license administration solution,
8:36:45 (lmgrd) FlexNet Manager, to readily gain visibility
8:36:45 (lmgrd) into license usage data and to create
8:36:45 (lmgrd) insightful reports on critical information like
8:36:45 (lmgrd) license availability and usage. FlexNet Manager
8:36:45 (lmgrd) can be fully automated to run these reports on
8:36:45 (lmgrd) schedule and can be used to track license
8:36:45 (lmgrd) servers and usage across a heterogeneous
8:36:45 (lmgrd) network of servers including Windows NT, Linux
8:36:45 (lmgrd) and UNIX.
8:36:45 (lmgrd)
8:36:45 (lmgrd)
8:36:45 (lmgrd)
8:36:45 (lmgrd) Server's System Date and Time: Fri Sep 14 2018 08:36:45 W. Europe Daylight Time
8:36:45 (lmgrd) pid 7292
8:36:45 (lmgrd) SLOG: Summary LOG statistics is enabled.
8:36:45 (lmgrd) Detecting other license server manager (lmgrd) processes...
8:36:48 (lmgrd) Done rereading
8:36:48 (lmgrd) FlexNet Licensing (v11.14.1.3 build 212549 x64_n6) started on SERVER (IBM PC) (9/14/2018)
8:36:48 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
8:36:48 (lmgrd) World Wide Web: http://www.flexerasoftware.com
8:36:48 (lmgrd) License file(s): C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic
8:36:48 (lmgrd) lmgrd tcp-port 27000
8:36:48 (lmgrd) (@lmgrd-SLOG@) ===============================================
8:36:48 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
8:36:48 (lmgrd) (@lmgrd-SLOG@) Start-Date: Fri Sep 14 2018 08:36:48 W. Europe Daylight Time
8:36:48 (lmgrd) (@lmgrd-SLOG@) PID: 7292
8:36:48 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
8:36:48 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
8:36:48 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
8:36:48 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
8:36:48 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
8:36:48 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
8:36:48 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic -l C:\Autodesk\Network License Manager\debug.log -z -s
8:36:48 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\Lisenser\Shark_2019.lic
8:36:48 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
8:36:48 (lmgrd) Starting vendor daemons ...
8:36:48 (lmgrd) Starting vendor daemon at port 2080
8:36:48 (lmgrd) Using vendor daemon port 2080 specified in license file
8:36:48 (lmgrd) Started adskflex (pid 9772)
8:36:48 (adskflex) Unable to initialize access to trusted storage: 1
8:36:48 (adskflex) FlexNet Licensing version v11.14.1.3 build 212549 x64_n6
8:36:48 (adskflex) SLOG: Summary LOG statistics is enabled.
8:36:48 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
8:36:48 (adskflex) SLOG: VM Status: 0
8:36:53 (adskflex) Server started on SERVER for:
8:36:53 (adskflex) 85787BDSPRM_F (consisting of: 87142BDSPRM_2019_0F
8:36:53 (adskflex) 86903BDSPRM_2018_0F 86696BDSPRM_2017_0F 86451BDSPRM_2016_0F
8:36:53 (adskflex) 86238BDSPRM_2015_0F 86071BDSPRM_2014_0F)
8:36:53 (adskflex) 86815AECCOL_T_F (consisting of: 87084ACD_2019_0F
8:36:53 (adskflex) 86830ACD_2018_0F 86604ACD_2017_0F 86445ACD_2016_0F
8:36:53 (adskflex) 86295ACD_2015_0F 87087ARCHDESK_2019_0F 86856ARCHDESK_2018_0F
8:36:53 (adskflex) 86480ARCHDESK_2017_0F 86480ARCHDESK_2016_0F 86288ARCHDESK_2015_0F
8:36:53 (adskflex) 87140CIV3D_2019_0F 86893CIV3D_2018_0F 86718CIV3D_2017_0F
8:36:53 (adskflex) 86514CIV3D_2016_0F 86354CIV3D_2015_0F 87088ACAD_E_2019_0F
8:36:53 (adskflex) 86635ACAD_E_2018_0F 86635ACAD_E_2017_0F 86481ACAD_E_2016_0F
8:36:53 (adskflex) 86290ACAD_E_2015_0F 87091MAP_2019_0F 86866MAP_2018_0F
8:36:53 (adskflex) 86719MAP_2017_0F 86517MAP_2016_0F 86355MAP_2015_0F
8:36:53 (adskflex) 87090BLDSYS_2019_0F 86855BLDSYS_2018_0F 86631BLDSYS_2017_0F
8:36:53 (adskflex) 86479BLDSYS_2016_0F 86292BLDSYS_2015_0F 86648PNID_2017_0F
8:36:53 (adskflex) 86517PNID_2016_0F 86301PNID_2015_0F 87153PLNT3D_2019_0F
8:36:53 (adskflex) 86894PLNT3D_2018_0F 86650PLNT3D_2017_0F 86517PLNT3D_2016_0F
8:36:53 (adskflex) 86296PLNT3D_2015_0F 87086ARDES_2019_0F 86832ARDES_2018_0F
8:36:53 (adskflex) 86606ARDES_2017_0F 86474ARDES_2016_0F 86294ARDES_2015_0F
8:36:53 (adskflex) 86720UTLDESN_2017_0F 86517UTLDESN_2016_0F 86356UTLDESN_2015_0F
8:36:53 (adskflex) 87149RVT_2019_0F 86917RVT_2018_0F 86706RVT_2017_0F
8:36:53 (adskflex) 86453RVT_2016_0F 86273RVT_2015_0F 86454REVIT_2016_0F
8:36:53 (adskflex) 86274REVIT_2015_0F 86456RVTMPB_2016_0F 86276RVTMPB_2015_0F
8:36:53 (adskflex) 86457REVITST_2016_0F 86277REVITST_2015_0F 87176NAVMAN_2019_0F
8:36:53 (adskflex) 86998NAVMAN_2018_0F 86766NAVMAN_2017_0F 86534NAVMAN_2016_0F
8:36:53 (adskflex) 86350NAVMAN_2015_0F 87152VEHTRK_2019_0F 86920VEHTRK_2018_0F
8:36:53 (adskflex) 86726VEHTRK_2017_0F 86565VEHTRK_2016_0F 86388VEHTRK_2015_0F
8:36:53 (adskflex) 870723DSMAX_2019_0F 868333DSMAX_2018_0F 866333DSMAX_2017_0F
8:36:53 (adskflex) 864713DSMAX_2016_0F 862623DSMAX_2015_0F 86263MAXDES_2015_0F
8:36:53 (adskflex) 87093RECAP_2019_0F 86984RECAP_2018_0F 86747RECAP_2017_0F
8:36:53 (adskflex) 86538RECAP_2016_0F 86402RECAP_2015_0F 87096ADSTPR_2019_0F
8:36:53 (adskflex) 86857ADSTPR_2018_0F 86612ADSTPR_2017_0F 86507ADSTPR_2016_0F
8:36:53 (adskflex) 86490ADSTPR_2015_1F 86375ADSTPR_2015_0F 87166CADMEP_2019_0F
8:36:53 (adskflex) 86938CADMEP_2018_0F 86777CADMEP_2017_0F 86519CADMEP_2016_0F
8:36:53 (adskflex) 86281CADMEP_2015_0F 87170RSAPRO_2019_0F 86941RSAPRO_2018_0F
8:36:53 (adskflex) 86659RSAPRO_2017_0F 86439RSAPRO_2016_0F 86297RSAPRO_2015_0F
8:36:53 (adskflex) 86937LIVE_2018_0F 86822DYNSTD_2017_0F 86643DYNSTD_2016_0F
8:36:53 (adskflex) 87151SBRDES_2019_0F 86919SBRDES_2018_0F 86792SBRDES_2017_0F
8:36:53 (adskflex) 86328SBRDES_2016_0F 87089AMECH_PP_2019_0F 86839AMECH_PP_2018_0F
8:36:53 (adskflex) 86627AMECH_PP_2017_0F 86478AMECH_PP_2016_0F 86279AMECH_PP_2015_0F)
8:36:53 (adskflex) EXTERNAL FILTERS are OFF
8:36:53 (lmgrd) adskflex using TCP-port 2080
8:36:53 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
8:36:53 (adskflex) SLOG: TS update poll interval is 600 seconds.
8:36:53 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
8:36:53 (adskflex) (@adskflex-SLOG@) ===============================================
8:36:53 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
8:36:53 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
8:36:53 (adskflex) (@adskflex-SLOG@) Start-Date: Fri Sep 14 2018 08:36:53 W. Europe Daylight Time
8:36:53 (adskflex) (@adskflex-SLOG@) PID: 9772
8:36:53 (adskflex) (@adskflex-SLOG@) VD Version: v11.14.1.3 build 212549 x64_n6 ( build 212549 (ipv6))
8:36:53 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
8:36:53 (adskflex) (@adskflex-SLOG@) Options file used: None
8:36:53 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
8:36:53 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
8:36:53 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
8:36:53 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
8:36:53 (adskflex) (@adskflex-SLOG@) === Network Info ===
8:36:53 (adskflex) (@adskflex-SLOG@) Listening port: 2080
8:36:53 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
8:36:53 (adskflex) (@adskflex-SLOG@) === Host Info ===
8:36:53 (adskflex) (@adskflex-SLOG@) Host used in license file: SERVER
8:36:53 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: Not determined - treat as Physical
8:37:00 (adskflex) TCP_NODELAY NOT enabled
8:37:50 (adskflex) OUT: "85787BDSPRM_F" Eli@SHARK123
8:37:50 (adskflex) OUT: "86903BDSPRM_2018_0F" Eli@SHARK123
Message 8 of 11
natasha.l
Hello @thomas_aardal
Which user/s are assigned the AEC license, how many seats do you have? Please check the assigned user/s, this behavior is as designed if the user assigned is pulling the AEC collection license first over the BDSP license. The Industry Collections like AEC do not function like suites especially when it comes to licensing.
Please review this post for more information on how to manage an IC license. Also, take a look at the IC FAQ & General information.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 9 of 11
thomas_aardal
What to you mean by "assigned"?
Message 10 of 11
natasha.l
Please review this short statement & link explaining what this would mean.
Account Administrator Manages Your Software (Named Users)
If your company has a Primary Admin who purchases software and manages its access, work with that administrator to set up your software. You can download, install, and activate your subscription software from your Autodesk Account after the administrator adds you as a Named User and assigns permissions to access software and services.
If you don't already have an Autodesk Account, your Account Administrator can create one for you when software permissions are assigned. You'll receive an email message that your permissions have changed.
Let us know if you have any questions.
Message 11 of 11
thomas_aardal
How is this relevant for network licensing?
