Network License Not Available: Error[-15.570.0]
blair
Mentor Mentor
Message 1 of 14
blair
Running Parallels 12 with Windows 10 on a MacBook Pro with a single license server. I've attached the debug log, Inventor 2018 can't find the license server. It appears that everything is running.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Replies (13)
Message 2 of 14
Otto
Hello blair and welcome to the Autodesk community!
It looks like you are seeing the following: "[-15.570.0] A valid license could not be obtained by the network license manager". This error has various causes. The following article(s) should help you resolve the problem:
Error: "A valid license could not be obtained by the network license manager"
Error: [-15.570.0] A valid license could not be obtained by the network license manager
How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable.
Troubleshooting FLEXnet Licensing Errors
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 14
blair
Thanks, I'll dive into this this evening. The debug log shows that the server is running with the correct license. The license server is running on the same machine as Inventor is. Trying the License File option returns an error. It's a simple Inventor and Nastran InCad 2018 license. I've tried creating and downing the license a number of times and get the same data in the License File.
The problem seems to reside with the "lmgrd". Not sure if running on Parallels is the issue.
Delta Tau Chi ΔΤΧ
Message 4 of 14
Mark.Lancaster
@blair
Not sure if this will help or not but you may want to review this article and the solution it provides.   You have the same error.   I will tag @TravisNave for his input...
Mark Lancaster
Message 5 of 14
blair
Thanks, will look at it this evening.
Blair
Delta Tau Chi ΔΤΧ
Message 6 of 14
DarrenP
this could be the solution: https://forums.autodesk.com/t5/installation-licensing/network-license-error-1-5-15-and-ipv6/td-p/298...
DarrenP
Message 7 of 14
Darin.Green
@blair
Thought I would share my two cents...
Error [-15.570.0] indicates a connection issue. Both links provided by @Mark.Lancaster & @DarrenP are good things to try, but I would also recommend checking the following:
  1. Technically, I recommend uninstalling LMTOOLS from C:\Autodesk\ and reinstall it to C:\Program Files\Autodesk\. However, if that's ok just move your license file from C:\Autodesk\ to C:\Autodesk\Network License Manager\License
  2. Give the Everyone user group full permissions to the Network License Manager directory and push the permissions down to sub-folders and files
  3. Disable the firewall or open TCP Ports 2080,27009-27009 for Inbound Rules
If this information was helpful, please consider using the Accept Solution
Message 8 of 14
blair
No network involved, all components are on a laptop. As an Expert Elite, we are allowed to use software under ADSK's NFR program. The only issue is that they only supply Nastran's InCad as a "multi-user" license requiring a license server for Inventor and Nastran.
Not sure if the issue is with running Parellels on this Mac laptop.
Delta Tau Chi ΔΤΧ
Message 9 of 14
blair
The issue still seems to be with the LMGRD. I've pasted the Server Status from the LMTOOLS:
Flexible License Manager status on Thu 7/13/2017 23:08 [Detecting lmgrd processes...] License server status: @BLAIRSTUNDE7B27 License file(s) on BLAIRSTUNDE7B27: C:\Autodesk\BLAIRSTUNDE7B27001c42332d9b.lic: lmgrd is not running: Cannot connect to license server system. The license server manager (lmgrd) has not been started yet, the wrong port@host or license file is being used, or the port or hostname in the license file has been changed. Server name: BLAIRSTUNDE7B27 License path: @BLAIRSTUNDE7B27; FlexNet Licensing error:-15,570 For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com".
Delta Tau Chi ΔΤΧ
Message 10 of 14
DarrenP
i assumed you were getting this on launch of Nastran
first verify if Flex LM is setup correctly with the correct MAC address & hostname
DarrenP
Message 11 of 14
blair
No, with Inventor as th Nastran is a plugin for it.
Yest the Hostname and MAC address are correct. I did a cut/paste from within the LMTools. Tried that a couple of times.
I can't get the Imged to start
Delta Tau Chi ΔΤΧ
Message 12 of 14
DarrenP
i have seen this caused by the hostname being wrong in the license file it was usually 1 letter or number is missing
another thing to try is put in the IP address instead of the hostname in the license file
DarrenP
Message 13 of 14
blair
I've done the License about 5 times using the Cut/Paste from the LMTOOLS utility. Both the License Server and software reside on the same machine. The MacBook Pro is a laptop that's not connected to any network.
Delta Tau Chi ΔΤΧ
Message 14 of 14
blair
Solved,
AVG, changed settings to allow LMTOOLS full access from the "Auto Choose" function.
Delta Tau Chi ΔΤΧ
