Network Licence Not Available
kumars4C9TZ
kumars4C9TZ
I'm trying to setup the AutoCAD 2018 Education license on one of our servers but I'm receiving a 'Network License No Available' error even though i have the license setup on the server correctly as i believe. The server is started, the services are all there and the license file is current.
Any ideas where I'm going wrong?
ennujozlagam
@kumars4C9TZ hello, you need to update license manager, try to check it HERE. thanks
kumars4C9TZ
I believe I'm already at the latest version. If you think there is anther version i should be on can you please forward em the link.
edwin.prakoso
Have you read this Knowledge Base? Error: [-15.570.0] A valid license could not be obtained by the network license manager.
My guess is your firewall blocks the license port. You can download and run this batch file to allow the licensing port. You need to run it as administrator.
Or you can manually open port 2080 and 27000-27009
Cheers,
Edwin Prakoso
