Mudbox 2015 wont start
Hey there Autodesk Team,
i bought a monthly mudbox 2015 subscription. downloaded it, started it ..everything worked fine.
closed it, tried to open it again and now i get stuck at the start sceen which says i should contact my admin to get the rights to use this product ..
I can type in my serial number and click activate .. after that i get back again to that screen .. and get an email which an activation code  .. but there is no field for the code to be pasted ..
please help 😉
thanks in advance ..
turritom
same here 🙂
this is where i always end up
tried to install the trial version ..
asked me to insert my serial number ..
said i have a license file already installed on that computer .. which will be used ..
getting stuck here again !
turritom
same here 🙂
PS: ganz genau da häng ich auch! diese völlig übertriebene (und sinnlose) Sicherheitspolitik von Autodesk ist einfach ärgerlich ..seit 2 Tagen probier ich hier jetzt rum.
hey turritom
its working for me now:
Paul Schicketanz: okay good .. already tried to install the trial .. but get stuck at the end at the same screen ..
Alessandra: Thank you for waiting. I'll be with you in just a moment.
Alessandra: Ok, it should be working now
Paul Schicketanz: okay , i see you added myself as an admin in my own account ?
Alessandra: yes, your contract was not registered in your account
Paul Schicketanz: could i have done that myself ? because i tried to add myelf as a user in my autodesk account
Paul Schicketanz: but i didnt worked
Paul Schicketanz: it
Alessandra: please note that these kind of licenses do not need an activation code
Alessandra: n, unfortunately not
Alessandra: you just need your userID and password
Paul Schicketanz: okay .. thats too bad .. but wait, ill try to start it
Paul Schicketanz: okay its working
So you have to contact the support over the chat system
they will add yourself in your own user account as the administrator for your account (a bit stupid) and you can not do it yourself ..
hope it helps you
turritom
thank you very much 🙂 i will try to contact the chat
