Microsoft Access Database Engine 2016 error requiring the 64-bit version to run AutoCAD Electrical.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I work at a college, and I am currently trying to install both AutoCAD 2023 Electrical, and some products from Rockwell Automation. AutoCAD 2023 requires the use of the 64-bit version for Microsoft's Access Database Engine (2016). This is an issue because the Rockwell software requires the use of the 32-bit engine. While going through the install, I received the error saying I could not have both 32-bit and 64-bit engines installed on my machine. I was wondering if anyone had a solution to this problem. Thank you!
