Maya LT 2020 will not run an longer?
mvtrappett
mvtrappett
I have Maya LT 2020 which would start okay, but for some reason it will no longer start?  You double-click the start icon on the desktop and the Maya Output window loads but stays empty. Then after about 20 seconds, it goes away, and Maya never starts.  It was running fine a week ago, now its dead?  I am fully licensed and this is so annoying.  I am running on a powerful machine, with Win 11, 32 GB RAM, and terabytes of disk space.
Please help!!!
Thank you,
Mark
pendean
Community Legend
Community Legend
Did you rememeber to install the MayaLT2020.1.4 update? It is required. More info here https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Maya-Rel...
If yes... what changed overnight with your machine that broke it? Often its an update of some sort, OS or other software (or removal of software). Dig around, try to find out.
Otherwise you're probably looking at a reinstall.
mdavis22569
Please help!!!
So one issue:
The latest upgrade to Windows 11 fully supports Autodesk Software versions 2021 and 2022. It is suggested to do a fresh installation of your Autodesk software once you upgrade to Windows 11.Dec 28, 2021
You're on 2020 which isn't .. possible one of the Windows 11 updates might have caused an issue?
Mike Davis
mvtrappett
I have reinstalled Maya LT 2020 and I am still having the same issues?
Maya tries to start showing the Output window and then dies after several
seconds. I disabled antivirus and VPN and still get the same.
I am to be charged another month's subscription in the next couple of days
and I am thinking about cancelling.
rushabhthakkar_910
@mvtrappett,
See if these help..!!
(https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Constant-...)
And this.. https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Maya-LT-c...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
mdavis22569
@mvtrappett
For:
Put a ticket in
Are you still on Windows 11? If so, that's an issue
Mike Davis
