Maya does not open on macOS Catalina
Message 1 of 35
I downloaded the student edition of Maya 2020, ran the setup and everything was working fine and today, the app just won't open! The icon just bounces in the dock and then gives me this error - The app "Maya.app" can't be opened. I did everything. Deleting all files and folders related to Autodesk and Maya, and reinstalling it. Still won't work.
My machine: MacBook Pro 13" 2018, 2.3GHz Quad-core, 8GB RAM, 512GB SSD. The 2019 version of Maya works fine.
Is there any solution to this?
Replies (34)
Message 21 of 35
worked, attached zip
Message 22 of 35
syracoj
Are you on Catalina?
We trust that you went through all the security settings and adding Maya to the Accessibility and Full Disk Access list?
You could also try this
- uninstall Maya
- install the standalone licensing app from the link below
- reinstall Maya
Let us know if this helps
https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-updat...
Message 23 of 35
Installed from link bellow
Installed Maya again
Result:
The application “Maya” can’t be opened.
This is really annoying, its clearly a problem on Autodesk side that should be solved.
Message 24 of 35
Hello, any news on my comment bellow? I am stuck wit this, and cannot work while I get Maya to open...
Message 25 of 35
syracoj
Out of curiosity did you try the install approach to installing to the MacintoshHD - Data Drive approach that can.j.lokman suggested on the first page of this forum post?
I have offered a few suggestions on possibly alleviating this with the manual license application install, as well as adding Maya to the Accessiblity and Full Disk Access list. If you are using a student version did you register the student version with your educational institute email address?
Maya licensing isn't really my domain of expertise so perhaps at this point in time the best course of action would be to contact Autodesk Maya support. You can do so here:
https://knowledge.autodesk.com/support/maya
On this^ page in the bottom left there is a blue button that says "Contact Support". Try to open a support case regarding this.
Message 26 of 35
Tried the Data Approach and all other recommendations, still nothing.
I tried more than 30 Maya installs for the past 7 days! : /
Will contact support, but its insane to have do deal with that kind of stuff
Message 27 of 35
i have the same problem, none of the maya is opening on my mac. i have tried every year version of maya lt
Message 28 of 35
Does this problem occur only with people with student license? Im on a student licence and Maya 2020 does not work, the same goes for Mudbox 2020. It is not working on macOS Catalina.
Message 29 of 35
syracoj
I trust everyone here did try the other listed items in this thread to workaround this?
And, you are using your student email address to register and obtain the license correct?
Please contact support as well. Perhaps there is a genuine problem with the academic licensing.
Sorry for any inconvenience, I have raised this with my Manager.
Message 30 of 35
I am also a student with the same issue, thanks for telling me this it works!
Message 31 of 35
ali.fx.esfandiariRZLKA
Observer
Observer
hi
i have maya 2022 and 2020 on macbook air m1, big sur. none of them works!.
I also read all the threads that you mentioned and follow al the instructions, but again Maya does not open
pi would be glad to hear a guid from autodesk .
so
cheers
ali mahdavi
Message 32 of 35
onghongjin
Community Visitor
Community Visitor
Have you solved the problem. I facing a same problem too
Message 33 of 35
i7977972
My render screen was blue for about 5 mins and then it started to render.
Message 34 of 35
syracoj
hey Ali,
did you install Maya on the Macintosh HD - Data drive?
Also, in the OSX sys prefs, under Security & Privacy, under Privacy category, is Maya listed in the Accessibility section, as well as the Full Disk Access, and Files and Folders sections?
Message 35 of 35
agougha
I know this is an old thread, but seems like this issue still persists on newer versions of Maya and newer OSX versions. I've been using Maya 2023 without issue on macOS Ventura, but some recent update has given me this issue.
Was driving me nuts, I would have to do a clean install of Maya 2023, have it work once, and then the issue come back the next day, rinse repeat.
This thread got me a workaround that was faster than reinstalling every day.
It seems for whatever reason, the Autodesk license service decides not to run intermittently, which you can see if you check it on Activity Monitor. Making it run by using the terminal command
sudo launchctl load /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist
gets it going again and Maya opens up without issue again.
Hope that works for anybody still affected by this issue.
I'd love to know why it's doing that in the first place, but in the mean time, this drives me significantly less nuts.
