Maya 2018 installation failing
Message 1 of 18
Trying to install Maya on a win 10 machine, fails with an error 26352 and leaves this in the log file:
2017/10/24:10:52:41 593997 BAH2UA7242HGP === Setup started on BAH2UA7242HGP by 593997 ===
2017/10/24:10:52:41 593997 BAH2UA7242HGP Path_Length: 140
2017/10/24:10:52:41 593997 BAH2UA7242HGP Current Directory C:\Users\593997\AppData\Local\Temp\_AI80BE.tmp
2017/10/24:10:52:41 593997 BAH2UA7242HGP Launch
2017/10/24:10:52:44 593997 BAH2UA7242HGP PageOpen LaunchDialog
2017/10/24:10:52:49 593997 BAH2UA7242HGP PageOpen LicenseDialog
2017/10/24:10:52:55 593997 BAH2UA7242HGP PageOpen ProductInfoDialog
2017/10/24:10:52:55 593997 BAH2UA7242HGP PageOpen ProductSelectionDialog2
2017/10/24:10:52:57 593997 BAH2UA7242HGP PageOpen FullProgressDialog
2017/10/24:10:52:57 593997 BAH2UA7242HGP Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2018_EN_JP_ZH_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2017/10/24:10:53:01 593997 BAH2UA7242HGP Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
2017/10/24:10:53:01 593997 BAH2UA7242HGP Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/10/24:10:53:01 593997 BAH2UA7242HGP Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Maya_2018_EN_JP_ZH_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2017/10/24:10:53:04 593997 BAH2UA7242HGP Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
2017/10/24:10:53:04 593997 BAH2UA7242HGP Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/10/24:10:53:04 593997 BAH2UA7242HGP Installing Autodesk License Service Certificate:   TRANSFORMS="C:\Users\593997\AppData\Local\Temp\_AI80BE.tmp\x64\CLIC\CLIC_x64_Release_certificate-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2018_EN_JP_ZH_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2017/10/24:10:53:11 593997 BAH2UA7242HGP Install Autodesk License Service Certificate Failed Installation aborted, Result=1603
2017/10/24:10:53:11 593997 BAH2UA7242HGP Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2017/10/24:10:53:11 593997 BAH2UA7242HGP Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Any ideas?
--BT
Replies (17)
Message 2 of 18
Otto
Hello Taylor_Keneth and welcome to the Autodesk community!
It looks like you are seeing the following error: Error: Microsoft Visual C++ 2012 Redistributable (x86). The following article(s) should help you resolve the problem:
Error: "Microsoft Visual C++ 2012 install failed, Result=-2147024546"
Error installing Microsoft Visual C 2010 Redistributable package: Generic trust failure.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 18
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Its failing on updating the Autodesk License certification.  I found this article http://www.teamsystemsolutions.com/support/knowledge-base/installation-fails-with-error-code-26352.a... but the solution is at your own risk.  I've never seen this error before so its at your own risk.  Smiley Wink
I will page @natasha.l for her input.
Mark Lancaster
Message 4 of 18
natasha.l
Hello @Anonymous,
Welcome.
Please let us know where you are pulling this download from, are you installing from a deployment?
  1. Try grabbing it from your Autodesk Account & try a Browser Download.
  2. Adjust Lan Settings & Proxy Setting
  3. Use Fiddler to locate web sessions being processed on the system, to locate network traffic
  4. System clock settings
Thank you for posting & let us know if you have any questions.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 5 of 18
I've tried installing view the web installer and a local deployment, neither gets past the error.
--Brad
Message 6 of 18
natasha.l
Hello @Anonymous,
Please try the download from your Autodesk Account, the steps above to make sure you have access to your systems folders & access to Autodesk services:
  1. Conduct a Clean Uninstall of the application & use the MSfixitTool to complete it
  2. Reboot the computer & log in as a Windows Administrator
  3. Clean out the TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Start Menu and hit Enter
  4. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  5. Use the Browser Download Method in your Autodesk Account
Let us know how it goes.
Message 7 of 18
natasha.l
Hello @Anonymous,
Have you given a different download a try? It could be related to the deployment or lack of prep for the install, the easiest way to know is to try another download.
Thank you for posting to the community & let us know how it went. Smiley Happy
Message 8 of 18
I've tried using a few different methods to no avail. I believe this is a problem with the way our company locks access to machines down. I am working with our internal IT to try and obtain full administrator access to install as I do not have that and I believe that is the problem.
--Brad
Message 9 of 18
Manually installing \x64\CLIC\Autodesk_License_Service_(x64)_5.1.5_Hotfix_1.msp and
CLIC_x64_Release.msi first before running the installer apparently tricked the installer in thinking the certs were there and allowed it to complete the install.
Thanks everyone.
--BT
Message 10 of 18
natasha.l
Hello @Anonymous,
Glad to hear you found an interesting workaround especially if you ran it with Administrator permissions by right-clicking & "Run As Administrator" would help as well.
As you mentioned, yes you need Administration permissions only during the install & first launch.
Thank you for letting us know about what resolved it & for contributing!
Message 11 of 18
Hi
It appears I am having the same issue as you were, "Install Autodesk License Service Certificate Failed Installation aborted, Result=1603"
We tried to troubleshoot it but couldn't find an anwser.
-we made sure we are the administrator on the computer
-we found that we already had the .NET installed
we tried to install "\x64\CLIC\Autodesk_License_Service_(x64)_5.1.5_Hotfix_1.msp" but when we ran the installer it said that that we might not have the program the it needed to update, or that we didn't have the latest version, we are trying to install the Maya Autodesk 2018
do you have any guidance?
Message 12 of 18
my system also says the same thing
Message 13 of 18
natasha.l
Hello @Anonymous & @Anonymous,
You can review the steps in >this article<, try the steps outlined to adjust proxy settings & whitelisting the domains necessary for license validation.
If the issue persists be sure to try Option 8: Regenerate Root Certificates.
Let us know how this turns out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 14 of 18
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue.
Message 15 of 18
uninstall both VC++ (x86,x64),and run setup again.it should work.
Message 16 of 18
libby_bass
I am having issues with installing Maya 2018. I get an error saying cannot open device or file specified C:\Users\Admin\AppData\Local\Temp\_AIA2F8.tmp\x64\Maya\Maya.msi
There is no AppData folder in Admin. Im running Windows 10
I have also tried a Browser Download and the Desktop App.
Please advise.
Cheers
Message 17 of 18
Mark.Lancaster
@libby_bass
Appdata is a hidden folder.  Are you viewing hidden files/folders?
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
Mark Lancaster
Message 18 of 18
libby_bass
Hi Mark
Thanks for the info. I followed the instructions but when I ran the Pre-requisite Checker nothing happened - ie. no results. It seemed to run it fine but then the window closed an no results were shown. I tried un-installing, and re-installing but the same problem. So I continued with the rest of the instructions in the Preferred Method for Downloading and Installing but I still had the missing Maya.msi. The folder was hidden so the file is there, as you can see from the attached.
Cheers
