- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I keep getting this error while trying to install Maya 2018 Student Edition on Windows 10: "1: 5 2: ERROR : Failed to install the anchor service. 3: 1001". I also get a similar error during the installation of Autodesk Licensing Manager: "1: 5 2: ERROR : Failed to install the anchor service. 3: 1007".
I had Maya 2018 installed before but one day it stoped lunching. I checked the forums and tried the clean uninstall and reinstall, switched off Windows Defender, Firewall and Windows UAC, found and repaired some issues with sfc /scannow, but nothing worked. Also I can't lunch the FLEXnet Licensing service, I get the "Access denied" error.
After several days of trying to fix the problem I decided to install the 2016 version of Maya, because on some forums people with a similar issue said it worked. But it also didn't install properly and after that I had problems uninstalling it.
I have no idea what else to do. Any help will be much appreciated.
