Maya 2017 on windows 10
I successufully install Maya, and I tried to run it the first time. The icon appears for one second on the bar and then disappears. No warning, no error, nothing at all. I'm not able to run Maya neither for put the educational license.
I have windows 10.
Any suggestion?
Thank you,
Cheers
Daniele
Otto
Hello dannox and welcome to the Autodesk community!
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking these pages and checking back often; we'll update with new information as our testing continues.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
I checked the suggestions but nothing seems to be wrong on the system.
In another computer of my colleague works, but not in mine, and he got windows 10 as well.
Should be helpful knowing where some message are stored, I didn't find anything in log events of administrative tools in windows.
cheers
natasha.l
Hello @Anonymous,
Welcome to the community! Smiley Happy Sorry for the Maya 2017 issues. I understand you are trying to figure out what went wrong with the installation of the program.
To generate a log file for the application please go to the Windows Start Menu > Run box (shortcut key Winkey+R) and typing%TEMP% into the box and clicking OK.
If you sort the files by date, you should be able to easily locate the Autodesk product installation .log file.  It will be named according to your product.  You can open this file in any text editor, such as Notepad and attach this file to your reply.
Hi!
thank you, the problem is related to license
2016-11-14 10:46:17: INFO: checkoutLicense: GetFeatureAuthorization Status 1 (Failure)
2016-11-14 10:46:17: ERROR: checkoutLicense: Failed to authorize license
2016-11-14 10:46:17: INFO: shutdown: ReleaseFeatureAuthorization Status 0 (Success)
2016-11-14 10:46:17: INFO: shutdown: normal exit
I got the educational and the _DEF_PROD_KEY is ok (checked in mail).
So what can the problem be?
Thank you!
Daniele
natasha.l
Hello @Anonymous,
Try running through the steps below, then try to launch the product.
Reset Internet Options:
  1. Clear the browser cache
  2. Browse to Control Panel\All Control Panel Items\Internet Option
  3. In the Advanced tab > Reset button to reset Internet Explorer's settings to the defaults
  4. In the Security tab, select Reset All Zones to Default level
  5. In the Content tab, select Clear SSL state
  6. Select Apply
In the Control Panel >> Internet Options >> Connections tab >> LAN settings >> Automatically Detect Settings
Let me know how it goes! Smiley Happy
I hope this answered your question or resolved the issue, if so please click Kudos or the "thumbs-up!" Did my response help resolve the issue? Please "Accept As Solution" to help others in the community.
