Maya 2017 installation error (error code 2711)
I got some error while I'm trying to install Maya 2017 on my pc. Please see screenshots below.
I tried both web install and install through Autodesk Virtual Agent. Same error messages pop out.
I have tried many times re-installing it. Anyone has an idea. Thanks for your time.
Otto
Hello keqing.yu and welcome to the Autodesk community!
It looks like you are seeing a Windows Installer Error Message. The following article(s) should help you resolve the problem:
Windows Installer Error Messages
Errors during AutoCAD software installation
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
I have no idea what it means. Also, below is my Maya2017Setup.log.
Mark.Lancaster
@Anonymous
Normally error code 2711 points to
  • It is may be problem with corrupted .Net Framework.
  • Application might be corrupted.
  • Improper uninstallation of Dotnet framework, your registry is not clean and might be corrupted.
  • Clean the temp and %temp% folder.
  • .NET Framework comes with the operating systems. So need not install it again. You just need to configure it from control panel.
Do you have Win 10?  Is netframe 4.7 installed?
Mark Lancaster
natasha.l
Hello @Anonymous,
Please review the system requirements, to see if you have the proper hardware, operating system & update etc. Make sure you have installed the following .NET Frameworks installed.
Let us know what operating system you are running this on just in case this is a systems issue related to an update.
1. Install the corresponding .NET Framework for Maya 2017
Microsoft .NET Framework 4.5.2 (for Windows 7, 8, and 8.1)  &
Microsoft .NET Framework 4.6.2 (for Windows 7, 8, 8.1, and 10)
2. Edit the registry to change the system's .NET version 4.6.2
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
