- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello I&L Community, industry collection, suite, activation, activate
This subject has come up quite a bit. Many members would like to know how to change their previously installed Suite products & make them Collection products. You can change this information depending on your particular situation.
If you originally installed from a deployment of 2016 & older products:
Conduct a Clean Uninstall of the applications
- Install & activate with the Industry Collection credentials
Note: The ProductInformation.pit file stores the Serial Number & Product Key information of all Autodesk products on the system located c:\ProgramData\Autodesk\ADLM\ProductInformation.pit the only way this is reset is by conducting a uninstall that is why you can not conduct the reset license function in this situation.
A suggestion for installing on multiple computers with multi-seat standalone licensing:
*The product can be installed on a local machine & the ProductInformation.pit file can be copied from one machine to another.(backup the file first)
*You can install the product on a local machine & create deployments for each product in the collection.
If you installed without a deployment:
- A Hard Reset of 2017 & Newer products should force a reactivation
- Activate with the Industry Collection credentials in your Autodesk Account
Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
