Installing Revit 2019 from Download Now option
renanrr3
renanrr3
Hello everyone,
I've been trying to install Revit 2019 using the Download Now option. I prefer this option instead Install Now because I never got around the last one (always a internet connection or some sort of problem unleashed havoc on the installation process and I had to start all over again).
I have download the installation files two times apparently successfully, but when I open the downloaded folder, I can't find any .exe or equivalent installation file. This is odd because I have too Revit 2020 installation folder and the setup.exe is sitting perfectly there.
Would anyone know how to proceed with the installation of Revit 2019 with the Download Now option?
Could it be possible that the download failed to transfer all the data two times, missing the .exe file? I find that oddly improbable.
Se below a snip from the download folder, so you can check everything is normal. There are only three main folders and a autorun.inf file.
Best regards,
use the browser method it will be easier
mdavis22569
Hi @Anonymous
Try AVA (Autodesk Virtual Agent)
https://ava.autodesk.com/
Here is the full offline installer from AVA
Please click on the link below to start.
Mike Davis
